Anyone have experience with DTMF decoding using 8870 or similar?
Hello,
I'm working on a project that will use a DTMF decoder IC (MT8870D) connected to a cell phone. I'll call the cell phone (w/diff cell phone), enter a PIN #,
DTMF decoder outputs the number, and the micro controller will read the number and respond appropriately.
I'm breadboarding the setup and find that I don't get *, 0, #. The decoder outputs to a BCD to 7-segment display driver. It shows all of the numbers, except
those mentioned. Those are in the row of tones that correspond to 941Hz. This freq. is in the middle of the minimum and maximum freqs used for DTMF: 697-1477.
So, it couldn't be getting filtered out? Could it? All other rows and columns work great.
My main question is... does anyone here have experience with using the DTMF decoders?
For input, the headset of the cell phone is wired directly to the input of the DTMF decoder using their differential input setup shown in the datasheet. I assume my
values for the resistors used are correct, because I'm getting great response for all of the other numbers that I input.
Any help would be greatly appreciated
"She may not be very pretty now, but she was somebody's baby once." Bugs Bunny
- Stephen
processor. I'm not sure why it's not working, however, I did notice that the data sheet states it has input filters, and there are some resistors listed for
the differential input that I didn't have the exact values for. I'm within 5% This may make a difference. Not sure. I'll get the exact values and test it again.
The output of the decoder goes blank whenever I press any key from the last row. With any other press, the number stays latched on the 7-segment
display--a little odd. I've never used one of these, so I'm not sure if this is normal.
Thanks for the reply.
FYI I have attached a table of touch tones and the corresponding output codes along with the output pins for the 8870. Depending on the version of the decoder you have pin 5 may also be important. It inhibits the detection of tones for keys A, B, C, D (column 4)
Pin 3 is the feedback resistor for input gain, and I will check that today. However, I'm think that it must be okay, 'cause I'm getting all of the other rows. But
I'll check the input. I checked direct output of the cell phone headset, and am getting a good signal--this was a problem before connecting directly to the
headset. Once I connected directly to the headset, it started working.
Pin5 is the inhibit pin, and I've tried it in both configurations. The odd thing is, when pressing keys in this last row, the display goes blank. Upon power up it
displays a zero. When I press 1, I get a one on the display. and 2 - 9 displays those numbers on the display. It's only when I try pressing any number in that
las row (*, 0, #) the 7-segment display goes blank--I would expect strange output on the display, but nothing; all LEDs are off.
Thank you for the reply. I plan on digging into this more this evening after work--I'm so close, I'm sure it's something very simple, and once I find it I'll give
myself a dope-slap and say Doh!
I checked it, and voil
