32bit assembler math
Hiya
Sure i've seen a link to some working code for 32bit assembler math, multiplication & division.
Can't see it in the links.
Can somebody point me a link?
James
James
mov r,#0 loop shr y,#1 wc if_c add r,x wc shl x,#1 if_nc tjnz y,#loopAssuming the the input is X·* Y
James
mov r,#0 loop shr y,#1 wc if_c add r,x wc shl x,#1 if_nc tjnz y,#loopshould be:
mov x,#10 mov y,#10 mov r,#0 loop shr y,#1 wc if_c add r,x wc shl [b]r[/b],#1 if_nc tjnz y,#loop ' result left in RA worked example·looks like:
Sorted!
James
{===== Peasant Multiplication =====} ' Stops on 0, works as long as the ' product fits in 32 bits. (So this ' is good for e.g. 24-bit x 5-bit.) ' All values treated as unsigned. peasant_multiply ' put the smallest op in op1 mov lo, op1 max op1, op2 min op2, lo ' clear the accumulator mov lo,#0 ' do the multiplication :loop shr op1,#1 wc,wz ' move the least significant bit of op1 into C if_c add lo,op2 ' if the bit was a 1, add op2 to the accumulator shl op2,#1 ' adjust op2 up by a power of 2 if_nz jmp #:loop ' continue if op1 is non-zero ' done...return the result in lo peasant_multiply_ret retJonathan
lonesock
Piranha are people too.
edit: and Chip came up with this uber-fast sqrt:
'' 'mask' is a register containing $40000000 which gets used directly and rotated all the way back to its original value mov root,#0 'reset root :loop or root,mask 'set trial bit cmpsub input,root wc 'subtract root from input if fits sumnc root,mask 'cancel trial bit, set root bit if fit shr root,#1 'shift root down ror mask,#2 wc 'shift mask down (wraps on last iteration) if_nc jmp #:loop 'loop until mask restoredJonathan
lonesock
Post Edited (lonesock) : 4/15/2010 3:49:40 PM GMT
Cool - thanks for that. Yours works - mine didn't!
Do you have a 32bit divide too?
James
asmdivide32bit mov t1,#0 ' no idea mov t2,#32 ' multiply/divide :mdiv shr y,#1 wc,wz ' divide rcr t1,#1 if_nz djnz t2,#:mdiv :mdiv2 cmpsub x,t1 wc rcl y,#1 shr t1,#1 djnz t2,#:mdiv2 asmdivide32bit_ret retput values in X and Y, and quotiant result is left in Y
James
