Pressure Sensitive Touch sensor — Parallax Forums
silverbacksilverback Posts: 40
edited 2010-04-14 21:46 in Accessories
If you need a quick (relatively easy) pressure sensitive touch sensor here is one that worked for me:
I found this sensor detects the following :
no contact
light contact (touching each pad)
higher contact (holding each pad)
highest contact (squeezing each pad)
Code
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' Code to use the pressure sensitive RCTime sensor
' -----[noparse][[/noparse] Constants and Variables ]-----------------------------------------
time VAR Word
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
DO
  HIGH 0
  PAUSE 1000                  'charge the Capacitor
  LOW 0
  RCTIME 1,1, time
  time = time - 10000 / 100  'this is for formatiing of the DEC
  DEBUG DEC time, CR         'used for StampPlot graphing
  PAUSE 500
LOOP
If you convince yourself that something is impossible before you even try; you are sure to prove yourself right.
  • Don MDon M Posts: 1,654
    edited 2010-04-14 12:10
    What program are you using that is producing the oscillograph on your pc?
    edited 2010-04-14 14:31
    Sweet! Thanks for sharing!
    I'm gonna try it [noparse]:)[/noparse]
    "puff"...... Smile, there went another one.
  • silverbacksilverback Posts: 40
    Don, the program is Stamp Plot Pro
    -general circuit update-
    I noticed a fair amount of reverse voltage would show up on the base when I would release pressure on the touchpad that connects to it, so I added a diode (1n4001) in line with the touchpad·to block reverse voltage.
    Post Edited (silverback) : 4/15/2010 10:24:44 AM GMT
