Mechanical question, using a set screw to attatch a cylinder to a bolt
Basically I've got a universal joint that I want to use in between two parts of a robot.· The UV joint won't spin, it's just being used as a left/right and up/down·bending joint.· The UV joint has a hole at each end that you put a round shaft into.· The shaft is held in place by two set screws on each end of the UV joint.· But in my design I will have the ends of the UV joint against a flat piece of plastic.· What I would like to do is drill a hole in the plastic, put a small bolt through the hole, put the UV joint onto the bolt, then tighten the set screws.· But I'm kind of worried about the threads on the bolt, that the set screws might not tighten down all the way.
- Stephen
