Run a DC motor using I/O pins
I am trying to design a vibratory system and i have connected an irregular·mass to the rotor of an
8000rpm miniature DC motor, when i apply power the motor gives an awesome vibration.
The problem I have is that I found out there is no way i'm gonna simply run the motor by setting·one·of
the BS2 pins·HIGH as there is only PLUS and MINUS in the motor, no way to feed in the signal!
I have a feeling that a transistor can·be of·great assistance but i dont know how to make exact connections
for the vibratory system. Can some1 give me a schematic of how to attain this. Relay switch can help but all
I·have in possession is an NPN transistor and a PNP transistor.
www.parallax.com/tabid/272/Default.aspx
http://forums.parallax.com/showthread.php?p=783327
