Tools for Sphinx — Parallax Forums
Tools for Sphinx
stevenmess2004stevenmess2004 Posts: 1,102
edited 2010-04-14 11:21 in Propeller 1
This is a thread for some tools for mpark's sphinx.
I'll start it off with a help viewer and files for it. It's extremely simple but hopefully useful. Also in the attached is a file for viewing some info from the sob files. Dump all the files on your sd card and compile sobread.spn and help.spn and then you can use them like
help [noparse][[/noparse]command]
command - command you want help for. All it does is display the file with the name command.hlp
sobread filename
reads some info in the sob file. You must include the .sob extension.
