FullDuplexSerial question
DiverBob
I was doing some experimenting with a Prop and FullDuplexSerialPlus.spin and a routine that was working with another prop chip doesn't work with the new prop. The only difference I can see is that the crystal freq is 8 MHZ on the prop that isn't communicating and the crystal was 10 MHZ on the one that did work. I didn't think this would make a difference but I can't see where else the difference might be. Could it be the crystal or should I look elsewhere?
Bob
Bob
BTW, I hope that you have actually ruled out hardware fault, ensure your 8MHz Prop is actually working with a simple blinky program or something. Always go back to basics and be methodical (don't assume or skip steps) when troubleshooting, it saves so much time and frustration later.
*Peter*
Bob
Leon Heller
Amateur radio callsign: G1HSM
