Another approach to a DIY CNC?
I've had this idea rattling around in my head for the last couple weeks.
(Due to the Propeller contest, and a thread on Savage Circuits.)
There are several folks who are working on a DIY CNC using a combination of salvaged parts and various materials.
What if...?
Most of the DIY CNC projects I've looked at use an old scanner as the base of the unit..
I've been thinking that if someone were use some common, but very specific sources for salvaging the parts,
say an HP Scanjet 4c (common and cheap) with an additional parts purchased from large "chain" sources,
we could create a CNC which could be replicated by almost anyone anywhere.
Obviously, I'm not talking about anything which is going to fabricate steel, but cutting plastic, or being able to
do PCB fabrication on my bench would be pretty slick.
There's the idea... comments? toss reality into it? [noparse]:)[/noparse]
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
What if...?
OBC
Hmmm, I can't say as I remember what the inside of the last scanner looked like that I took apart.· I suspect that it would be far too weak to do much of anything beyond moving the light bar inside it.· As they are driven by stepper motors, having an under powered machine is a really bad thing.· Once your stepper skips steps, they can never be made up and the end result is not going to be so good.
Perhaps you could look for some flat-bed plotters. I remember those being fairly robust.
Chris
If you used a LASER or a Plasma Torch as a cutting medium, there is no lateral force on the cutting tool!
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
cgi.ebay.com/808nm-DPSS-pump-high-power-burning-laser-diode-1-watt_W0QQitemZ180488966749QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a05fb125d
For larger items like plastic try this
cgi.ebay.com/High-Power-Laser-Module-450-mw-Cutting-Burning-diode_W0QQitemZ180446582275QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a03745603
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
The first thing you need to do is decide what you want·Your CNC to do.
CNC machines do everything from cutting, making screws, carving wooden signs,·to measuring the thickness of Bubble Gum.
Next you·have to determine the accuracy needed for your machine.
A lot of the cheaper CNC Kits use a PC as host and stepper motors in open loop mode.
There is no way to correct for any position errors as the system does not know where it is.
It navigated bt 'Dead Reconning'
This works suprisingly well, when you are not pushing a cutting tool very hard.
Plasma torches and routers work well, and knives and lathes do not work as well.
This would push the limit of a Stamp but the Propeller should work well.(I havent figured the prop out yet. 41 years of Basic programming is hard to undo!!)
The next step is Servos or Steppers with encoder feedback.
This would allow your machine to correct for position errors.
It puts more burden on the CNC to track Actual position versus CNC Position.
This is called following error, and is helpful to keep your finished product inside your design parameters.
Check out··· www.cnczone.com
They have lots of information on all types of CNC's and most of them are hobby grade products and people.
There is also a forum on many diffrent types of CNC's.
It may be easier than reinventing the wheel.
Good Luck,
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
