Battery Trouble
Hi!
I purchased two of the serial servo controllers b4 they were discontinued (first link).· I'm tryin to build a sort of robotic spider.· 8 servos for leg back and forth and 8 for leg up and down.·I finaly have some time on my hands, and was gona sit down today and plug in some servos for some fun...· Then I realized that i need a power supply that provides a large current.·· so my question is this.· If I were to stick on 16 servos, (140 +/- 50 mA)(second link), (2.24A-3.0A).·· I would hopefully only run about·8 to·10·at a time,· what kind of supply would i be looking at?· would it be simaler to the boe-bots 4 AA supply?
I've been reading forums the last hour about mA hours and understand that they are a measure of how long a battery will last depending on the current drawn.· But I dont understand if a AA can pump out a significant·current for a short period of time say like 10-15 minutes or if that would blow it up.· Any help would be appreciated.·· (first time posting in forum hope this was the right one... lol)
Electro
http://www.parallax.com/Store/DiscontinuedProducts/tabid/795/CategoryID/69/List/0/Level/a/ProductID/376/Default.aspx?SortField=ProductName%2cProductName
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/900-00008-CRServo-v2.0.pdf
Electro
Different servos have different internal gearing. Depending on the walker's weight, leg geometry, and servo gearing, the servos will consume a certain amount of power even if the walker isn't walking. Just standing up without collapsing will drain the battery.
Walkers are very cool and engaging to watch, but they will quickly make you appreciate the simplicity and efficiency of wheels!
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
mabye ill have to go back to a roller design. I'm attending a college electronics program right now so ill see if they have any fancy battery packs i could borrow/buy. Ill look into teh rc battery packs. Thanks guys!
If i get it moving ill post a link to a movie!
electro
http://www.onlybatteries.com/showitem.asp?ItemID=14501.55&cat1=12&uid=1010
Is this sort of what you guys meant for rc nickel metal pack?
http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=Battery_Toys&product=2300321
Do you guys think a six volt lantern type battery like this may be able to pump out enough current?
http://www.canadiantire.ca/AST/browse/7/Electronics/HouseholdBatteries/Batteries6Volt/PRD~0651046P/Energizer%2B6%2BVolt%2BSquare%2BLantern.jsp?locale=en
http://forums.parallax.com/showthread.php?p=874324· and now the builder Jamie is building a big one to ride in... His·many Youtube videos·are amazing.
And of course, there is an add-on to make a six-legged walker out of a 2-wheel BoeBot.
With that said, it opens up a can of worms when it comes to battery chemistry.
Here's a link that should help get you started.
www.powerstream.com/BatteryFAQ.html
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
Something like that; this is a bit cheaper -
You'll need a charger too, and that's kinda the downside to using these types of batteries. The good news is that a charger like this will last you many years and will be able to charge just about anything you need.
This one is a bit more expensive because you can plug it into a wall outlet as well as hook it up to a car battery. Most chargers like this need a 12 volt supply.
Rich H
The d-cells are on sale at an electronics outlet (The source).·· I figure ill rig 5 or 4 D cells in series (1.2V*4 or 5=·4.8-6V).· The D-cells are half off so it should be perfect!· They sell 1 and two d cell holders, unfortuneatly plastic.··
I realized that I have a second servo controller so I can put 8 servos on each reducing the current draw(means 2 power sources thou).·
do you guys think this will work?· Thanks for all the feedback!!
http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=Rechargable+Batteries&product=2300523
http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=BatteryAccessories&product=2700386
energizer
http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=Rechargable+Batteries&product=2311464
other
One type draws about 100 ma no load and 0.46 A loaded and stopped.
The other kind of servo that i have draws about 0.25 A loaded and stopped
(measurements taken at 5V through the basic stamp board for the boe-bot with a 9V battery attached)
I have 8 of each type so that means that...
8*0.46 =· 3.7A
8*0.25 = 2A
total = 5.7 A
total divided by 2 = 2.85 A
Will 5 D cells be capable of providing 2.85 amps without a boom?
reason im figuring on d cells is becasue W9GFO mentions a 5 cell sub c pack.· my understanding is this is esentialy would be 5 c cells in series making 6ish volts.· Is this right?· thanks again guys*!
*and gals!
electro
The current drawn from or going into a battery can be expressed as "C". If the battery capacity is 2,000mah then a 1C discharge is 2 amps (2,000 mah / 1C = 2,000ma aka 2 amps) and a 10C discharge would be 20amps.
It is common for RC packs to be rated for 10C - which means you could drain the pack in 6 minutes! Some LiPos can handle up to 60C for short periods.
So, 5.7 amps for those 2,500mah "D" sized cells would be 2.3C. However, you probably would only be drawing half that at any one time so that brings it down to just over 1C. Those "D" cells don't offer any additional capacity over AA cells so the AAs would also be about 1C. I think it is reasonable to assume that nearly any AA NIMH can handle a 1C charge current (1 hour to charge) and therefore can also withstand the same discharge current.
The reason the sub-c cells are more desirable is that they are made for high discharges, whereas AAs are designed for lighter duty (those "D" cells may be just AAs in a larger package). If you draw too much current from a AA it will overheat, possibly with a runaway thermal reaction. I do not know how much is too much for a AA but I would not feel comfortable with more than 1C.
Rich H
I've run the poo out of my pack from cheapbatteries, 5x1500mah 2/3A Elite cells.... Average 5A discharge rate on a brushed motor system....... The motor is toasty, the pack is about 110degrees and I've never noticed a change in the pack.
"puff"...... Smile, there went another one.
The Sub-C cells commonly used in RC packs are just slightly smaller than a standard C. They measure about 22mm x 44mm vs. 26mm x 50mm for a standard C.
Rich H
Here is the balancer http://www.rctoys.com/rc-toys-and-parts/TP-205V/RC-PARTS-CHARGERS-BALANCERS-POWER.html
here is the battery i plan on getting http://www.rctoys.com/rc-toys-and-parts/TP-2600-2SPL2/RC-PARTS-THUNDER-POWER-LITHIUM-BATTERIES.html.·
here is the power supply http://www.rctoys.com/rc-toys-and-parts/K-TP-535-1205P/RC-PARTS-COMBOS-LITHIUM-CHARGER.html
thanks!
Aside from that, a balancer will monitor each cell's voltage while charging and prevent overcharging one cell in that two cell pack. The more you use a pack, the less balanced the cells will typically be..... and die long before it's time. Been there, because I didn't want to spend the $30 on a balancer.
I'd say forget the Lipo, and if you still buy it.... the balancer is NOT optional. Never ever leave it unattended in charge or discharge. We lost $20,000 in building and equipment because of a charging Lipo was left unattended.
I use em' all the time in RC. Just saying, they require respect and attention.
The Thunder Power Lipos are usually VERY good batteries. That's not a bad price either.
Good luck
Post Edited (Spiral_72) : 4/16/2010 2:35:40 PM GMT
For just a bit more you can get this charger - www.rctoys.com/rc-toys-and-parts/TP-610C/RC-PARTS-CHARGERS-BALANCERS-POWER.html - which can charge all types of batteries, and it has a built in balancer. You'd still need to get the power supply though.
Rich H
I use Thunder Power batteries in all my RC planes and helicopters, but I would probably not use it in a robot. I'm more a fan of RC car NiMH or SLA (Sealed Lead Acid) for a robot platform.
The batteries are cheaper, the chargers are cheaper and you can get them at Radio Shack, Wallmart, Target.
My 2 bits
Jim
I have foudn a website that has a wide varity of nimh batteries for 6V.· This one has 10 amps max and many other 6V batteries!
http://www.onlybatterypacks.com/showitem.asp?ItemID=10413.7
This may be a stupid question but does anyone know about or ordered from this company?· credit card fraud and all worries me...lol
thanks!
