Communicate with Basic Stamp at 38400 Baud!
Hello,
Here I have find a IC, that can communicates with a microctroller like BS2·at 38400 Baud rates! The IC is RSB6505, and has a typical communicates rate with host of 38400, 19200, 9600 or 4800 baud,·IC·buffers up to 64 bytes of·RS232 serial data.
For those who don't know the RSB6505, here is·data sheet of RSB6505, there is schema of Basic Stamp to RSB6505 and some code too.
Post Edited (electrosys) : 4/11/2010 6:56:23 PM GMT
Something that I can't understand is the connection of MAX232A and D9, here the pin14 of MAX232A which is RS232 output, is connect to D9 pin3=TX
and pin13 of MAX232A which is RS232 input, is connect to D9 pin2=RX ! Shouldn't it changes the places of D9 pin3 to D9 pin2 ?
Look at the above post: imag attachment or RSB6505.pdf data sheet.
At the end, everything will became Electrons...!
