Objects or connections gameboy advance LCDs?
Oldbitcollector (Jeff)
Has anyone done any work with the gameboy advance LCDs? Either of the models?
Thanks!
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
Thanks!
OBC
I've made a lot of search to find those LCD pinouts, but it's impossible to find any data for them as there are OEM components.
The best way to use them is to use the entire GBA console, inside you have :
- LCD
- Buttons
- Loudspeakers
- ARM processor
- 256Ko Ram
It makes a good terminal for projects !
You can programm the GBA in C it with VHAM or a GNU toolchain, and use a serial link to the propeller to send commands to the GBA program.
Best regards
Line up the buttons, etc and use the case as it is. I was just hoping that some data had leaked somewhere to
reuse the screen at the same time.
Guess it's time to take some measurements on the screen and find a suitable replacement which is compatible with the Prop.
OBC
Here Comme LCD SCH to GameBoy.
If It help You I will be happy.
I have most SCH's to GameBoy If You need that
Regards
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Is it a Game boy ADVANCE lcd schematic or a Gameboy one ?
If you have the GAME BOY ADVANCE schematics, I'm interested !!!!
Best Regards
