Parallax Part # 900-00001 Piezo Speaker can this be used with a LM386 Need T
·Will this work or do I·need to use some thing else
·Here is the Link to it ...>>>>> ··· ·Piezo Speaker·
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 4/11/2010 1:01:43 AM GMT
··Thanks for any·
Sam
Leon Heller
Amateur radio callsign: G1HSM
And how would you do this Please give an Example
··Thanks for any·
Sam
Leon Heller
Oh ??
If an output pin is 5V or Gnd, you've still only those potentials.· Anti-phase, anti-matter, anti-clockwise, or maybe this is about XMOS?· That's it, it's the XMOS Factor; yeah, Stamps don't do that.
Leon Heller
Post Edited (Leon) : 4/11/2010 2:36:29 PM GMT
I say that the same thing could be done by sourcing the oscillation from a Stamp output pin.· "What's the frequency, Kenneth?"
[noparse][[/noparse]Sorry, sam_sam_sam, but this Subject may go sideways from hereon.]
And then I thought: Cool, kV; a Stamp-based shock-wand ("taser") in Completed Projects.
Post Edit -- How about that little somethin'-somethin' for your BoE-Bot?
Smaller caps (multiplier)·mean a shorter (faster) charge-up time, but less current (ampere-seconds), too.·
Post Edit --
Capacitors should be rated WVDC > final output voltage, and the diode PIVs, too, say I.
Post Post Edit -- I should have started another Subject, but then I'd have to do all the work.· Sorry.
OK, if anyone is interested in the "HV" aspect, I've started a new Subject --
http://forums.parallax.com/showthread.php?p=897801
Post Edited (PJ Allen) : 4/11/2010 7:22:26 PM GMT
Here is a link where I posted something several years ago on how to drive a piezo...
http://forums.parallax.com/showthread.php?p=464410
...for 3.3V drive, substitute the 4.7K resistors with 3.3K resistors.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 4/11/2010 5:53:24 PM GMT
·Posted 8/21/2004· ·>>>>>
Typically when you use a piezo, one terminal is connected to a microcontroller, while
the other terminal is connected to ground. When the pin goes HIGH, the piezo is deflected in one direction producing a
"click"...when the pin goes LOW, the piezo relaxes producing another "click". By using an inverter you can effectively
deflect the piezo in each direction past center creating a noticable increase in volume.
How do you· write this in·code
Can you Please give me an example
If I went with an LM386 chip to do this where would I find a very small round·speaker that would be able· to handle 1.25 watt of power
a web link please
Thanks for any help that
··Thanks for any·
Sam
This technique is what I used for the design of the SoundPAL:
It took a lot of experimenting to get it right, but made a huge difference in the volume level and audio "fullness" produced by that tiny speaker. Eventually, I made a mandrel over which the shrink tubing could be formed in a production environment. It not only sets the length of the inner chamber, but also keeps the inner diameter of the snorkel from closing too far when shrunk:
··Thanks for any·
Sam
Not sure how different this part is, but here is the buzzer that is used in the schematic. search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=102-1269-ND&x=0&y=0
Post Edited (Todd Chapman) : 4/14/2010 6:57:29 AM GMT
