Number of PUB/PRI limitations
Dave Hein
I seem to recall that the number of methods per object is limited to 64.· However, I can't find this documented in the Prop manual.· Can someone point me to where this is documented?
I'm pretty sure we did not document the limitation on methods per object. I'll note that for the next update.
Here's the details:
For each individual object, the total number of methods plus included objects can not exceed 255.
For example,
I don't know if there is anything in the Spin language that has a limit of 64.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Post Edited (Jeff Martin (Parallax)) : 4/9/2010 9:15:10 PM GMT
Thanks for the response.· The 64 number may be a nested-loop limit or something else.·· It's good to know we can have up to 255 methods plus objects per object.· I was around 64 methods in one of my objects, and I was concerned about hitting a limit.
Dave
Case statements.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
Thanks for posting the list of limits.· I know I've seen this before somewhere, but I can't recall where it was.· I just ran into the 16 ELSEIF limit tonight in a command-line parser.· I'll need to restructure my code to get aound that.
Dave
