Does Waves have Inertia and Momentum?
william chan
Consider a disturbance, lets say a stone is dropped in the middle of the pond.
That disturbance will cause circular waves to be propagated equally in all directions away from the disturbance.
Next, consider a wave that is traveling towards one end of a pond.
If we take a snapshot of the wave with a camera, we can visualize the crest and the trough of that wave.
At the point of time when the snapshot was taken, the crest and trough can be considered a vertical disturbance to the equilibrium of the water.
Theoretically, after the snapshot, new circularly outward waves should have been created from that momentary disturbance seen from the snapshot.
In practice however, we notice no such thing and the wave continues to propagate in the same direction after the snapshot, as if it has horizontal inertia and momentum.
Any explanations?
www.fd.com.my
www.mercedes.com.my
Any explanations?
www.fd.com.my
www.mercedes.com.my
It's complicated a the seashore by the fact that the waves are reflected from the shore, often with great distortion due to the shallow slope, so it might not seem like the water is "going anywhere." But as we see with tsunamis, waves are capable of transporting large amounts of energy for very large distances. If the sea were infinitely large the wave would travel forever, taking a certain amount of water permanently away from the place where you dropped the stone. But in practice all waves end up getting reflected back to their point of origin, so it's not as obvious that they transport energy.
At the point of the snapshot, new circular wavelets are generated from every disturbance point, especially the whole length of the wave front.
The sum interference of all the circular wavelets will add to become a new wavefront which seems to propagate in one direction.
The question is,
Why did the sum of all circular wavelets add up in such a way to create a major wave that continue in the same direction of propagation?
Is due to the shape and manner of the disturbances at the point of snapshot? Is it due to an inherent "wave inertia"?
As far as we know, only mass has inertia.
www.fd.com.my
www.mercedes.com.my
Not quite accurate. If the wave were linear, then sure. But, in the case of a dropped stone (or perhaps soyuz spacecraft) the waves would be radial. In that case the waves would get progressively smaller the further you are from the origin, until you get to infinity (via a limit), in which case the wave is gone (negligible).
Also a point to note is that waves (as defined in physics) are a form of transmitting energy through a medium. Waves are not matter, therefore they cannot have momentum or inertia. The medium that the waves act upon (the water, a rope, air, etc.) can have momentum and inertia, since there's mass. But the wave itself, no.
Powered by enthusiasm
UC Berkeley '12 EECS
CalSol: UC Berkeley Solar Car
http://calsol.berkeley.edu
KJ6AWU
In the case of a breaking wave, the undersea surface is even more incompressible than the water and coming up so the pressure front has to go up higher. At some point it gets pushed so high it's unstable and falls. The falling action does create horizontal displacement.
I love physics!
Signature space for rent!
Send $1 to CannibalRobotics.com.
