Simple, Nifty Walker
Looks like a 2-motor robot. Nice job by the builder, let's find him!
http://www.youtube.com/watch?v=_6qpSOjtB2E&NR
His videos of making the giant version of that robot are hilarious.
Check out the Propeller Wiki·and contribute if you can.
"A complex design is the sign of an inferior designer."
- Stephen
www.pololu.com/docs/0J42/all
humanoido
Check out the leg build of the Gigantic Spider Robot he's working on...
www.youtube.com/user/JMEMantzel#p/a/u/1/aMU3Q7n33HY
Edit:
If you've ever questioned your own ingenuity as far as how on earth you were going to get from point A to point B, I urge you to watch this guy's videos. Truly inspirational original solutions to very complex problems, and this guy just seems to do it and get the job done.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/29/2010 5:00:37 PM GMT
My guess is that the gait pattern generator is in the rotating head. The exact details of how this is done I can't see either. I'd LOVE to see some close up pictures of that walkers guts.
Lawson
Lunch cures all problems! have you had lunch?
In case you didn't know, it's all done with just 2 motors. One drives the motion of all 6 legs, and the other turns the top bit around including turning the other motor around along with it's connected gears and what not. If you number the legs 1-6, then the top part of the even legs and the bottom part of the odd legs are all connected to a center rod. That rod moves in a up->forward->down->back circular motion. Due to the linkage of the legs to the chassis the circular motion causes it to walk with a gait where 3 legs are on the ground and pushing it forward while the other 3 legs are lifted up and moving forward. If you take that center rod and the mechanism driving it and rotate it around, that changes the direction the thing walks in.
If I had a cnc machine I am pretty sure I could make a working bot.
I agree. It's most likely a two-motor setup where one motor does all the leg driving through eccentric linkages or cams, and the other simply rotates the whole drive mechanism relative to the base & legs. It's very well done.
Along the lines of how the Toddler/Penguin manage a variety of gaits and turns with 2 servos by changing the phasing of the motions.
Beau Schwabe
IC Layout Engineer
He also went off to Alaska for 8-9 days and helped a friend build a most of a log cabin. It's crazy how productive he is. I wish I was 1/4 as productive.
- Stephen
Pi aren't squared, pi are round. Cornbread are squared!
