Hey guys I'm trying to measure light using the StampPlot Lite but when I try to connect the COM3 which is the one that the BS is one it says that that CON is unavailable...any help ?
Well, the BASIC Stamp is using the port, my BS is connected to COM3 and it says to connect the StampPlot to COM3, when I try to do so I get the message.
If you have DEBUG statements in your program, the debug window will open and block the port. If that's the case, you will need to either change your DEBUGs to SEROUT 16 ... or close the debug screen each time.
Closing the DEBUG terminal is not working, I even deleted the DEBUG statement and the terminal would still show up...what is that about the SEROUT 16..
Copy the code below into notepad save it as fix.reg then double click on the file - it should update your registry:
Windows Registry Editor Version 5.00 [noparse][[/noparse]HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{648A5600-2C6E-101B-82B6-000000000014}]
"Compatibility Flags"=dword:0
Hopefully StampPlot will work now, if not - To put your registry back do the same with this code:
"Compatibility Flags"=dword:00000400
Yup, it worked now..the StampPlot is ready the data..it displays 0's and g's when I put my hand over the photoresistor but I don't see any kind of plot in the graph....lol..any help with this?
Unfortunately I know more about Comm than I do StampPlot - Now that we got it working, you need a StampPlot expert. I'm glad we got this far though. Good Luck.
- Stephen
this is my program
' {$STAMP BS2}
' {$PBASIC 2.5}
time VAR Word
DEBUG "!AMAX 1250", CR,
"!TMAX 25", CR,
"!TMIN 0", CR,
"!SHFT ON", CR,
"!RSET",CR
DO
HIGH 2
PAUSE 100
RCTIME 2, 1, time
DEBUG DEC time, CR
LOOP
- Stephen
If you convince yourself that something is impossible before you even try; you are sure to prove yourself right.
it the "Compatibility Flags" = 00000400
the set it to 0 and try the program again. if it works great if it doesn't set the registry back to hex 400.
Why? If it works it's because StampPlot is using MSCOMM which is blocked by newer internet explorer.
And why is it blocked - i believe some malware use activex components and this is MS's way to stop them.
Have Fun
TR
name value
compatibility flags 1024
when I try to modify it, it won't let me
Have Fun
TR
Warning messing with registry can goof stuff up royally!
Backup your registry first then
Open Command Prompt.
Type
reg delete HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableRegistryTools
Answer y.
once you in check your run and run once registry keys under HKLM & HKLU to see if you are infected
Run an antivirus
Have Fun
TR
Post Edited (TechnoRobbo) : 4/6/2010 9:24:33 PM GMT
you can try this:
Have Fun
TR
Have Fun
TR
- Stephen
g
g
g
g
0
0
0
0
0
0
g
g
g
g
DEBUG "!PLOT ON",CR
to get it to go?
Have Fun
TR
- Stephen
This may sound like a stupid question - but did you hit the "Connect" button and the "Start Plot" button?
I tested the plot below with your output code and it worked
Have Fun
TR
Post Edited (TechnoRobbo) : 4/8/2010 9:40:22 PM GMT
As you can see it works fine - is your wire connected to pin 2?
Im also Assuming you are using a photoresistor with a .01 microfarad cap·in parallel
post edited cause I had .001 instead of .01 and forgot the word "cap"
Have Fun
TR
Post Edited (TechnoRobbo) : 4/10/2010 4:49:41 PM GMT
3
3
3
3
3
3
then it raises up to 40s when I block the light..
