Catalina C source code debugger released (BlackCat 1.35) — Parallax Forums
Bob AndersonBob Anderson Posts: 122
edited 2010-04-13 00:47 in Propeller 1
BlackCat is a Windows based source code debugger for use with Catalina C 2.4 (available here) and is particulary easy to use with ViewPort 4.3.2 (available here)·(which adds C code editing and automatic invocation of Catalina and BlackCat).· It allows you to step through your code in a variety of ways, place breakpoints, examine and modify variables while at a breakpoint, trace calling path, etc, and supports XMM LARGE and XMM SMALL as well as LMM on a variety of commonly available hardware platforms such as MORPHEUS, TRIBLADEPROP, HYDRA, HYBRID, DEMO, etc.
If you haven't installed Catalina C 2.4 yet, I have included a demo that was compiled using Catalina 2.4 (I used ViewPort 4.3.2 as the IDE)·that you can use right now to get a little "stick time" on BlackCat.
Unfortunately, though we tried hard, BlackCat will not run under Linux.· To serve that community, as well as those that prefer to use command line utilities, there is a command line version of BlackCat (called BlackBox) that Ross Higson built and·has been·released with Catalina 2.4.· It strongly parallels BlackCat, so running BlackCat will give you a good feel for what BlackBox will provide.
The necessary files are·now only available·on the Object Exchange (here).·
There is a demo to get you started without the need to have Catalina installed.
To run the demo, you will need a serial connection to a propeller chip.
In the BlackCatDemo directory, navigate to bin/Debug.· There you should find three files named DemoProject with .binary, .dbg, and .lst extensions.· Use the Propeller Tool to load DemoProject.binary to your propeller.
Go to wherever you unzipped BlackCat and open blackcat.exe.
On the Propeller Communications panel that opens up, select 115200 baud.· Then click the COM port drop down box.· It will be populated with available serial ports.· Select the one that is connected to the propeller.· Then click Open.· You can close this dialog now.· All settings are "sticky", and if you had been using ViewPort, all this would have been done for you.
On the BlackCat panel, click the menu item Open dbg file.· Navigate to DemoProject.dbg and select it.· You should be debugging now!· Use the Help menu item to bring up on-line help.· The on-line help is a manual organized around the kind of questions a new user will have.
Have fun.
Post Edited (Bob Anderson) : 4/8/2010 2:41:18 PM GMT
