Shop Hint
I never throw away power cubes. To make them instantly versatile, I put a header on them and label with BIG print.
Makes them easy to find and a cinch implement.
You'll save on batteries and time.
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Jim-
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Brian
"Imagination is more important than knowledge..." Albert Einstein
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
Rich H
Powered by enthusiasm
* Sort (what do you need/not need in a given area)
* Set in Order (a place for everything, and everything in it's place)
* Shine (make in clean, not just neat)
* Standardize (labels, clarification, understanding your role in a multi-person environment)
* Sustain (keep the discipline)
Or for "5S + 1", add Safety.
The first one (Sort) can get kind of funky. It's about getting stuff you don't need at hand "gone". Either in a remote (relatively) storage area, or just plain "gone".
Look around the typical work area. How much of the stuff within arms reach do you really use more than once a month? Of that, how much would you know you would need before you started working on a given task (meaning you could collect it for the one job/task, and then put it back, out of the way).
John R.
Click here to see my Nomad Build Log
Then the replacement cost can come from HER pin money...
John R.
The thought of missing out on those opportunities motivates me to continually pursue an ongoing appearance of being "strategically unorganized." It's tough, but I demand a lot from myself so my wife doesn't have to bear that burden.
Ya, she's very fortunate indeed, I must say.
