VGA Problem
Hi!
I have a Propeller Protoptype Board. I soldered the VGA connector and registers properly.
After compiled the vga_demo.spin object (from 'Propeller Library - Demos') into it, when I am connection the board with a CRT monitor (desktop monitor)
the green led in the board is getting switched off and the voltage regulator becoming hot.
What should I do ?
But the chip is working now.
What should I do ?
Oh San you also didnt say how hot my reg does get a bit warmer when I am running the VGA monitor I actually had to add a heat sink and it only got hotter when the monitor was attached do the colors show up OK?
But I checked so many times; I placed all the components in right place and there is mo shotr-circuit.
Why the power led in the board is getting low when I'm connecting Monitor ?
If the battery is down then can it be happened ?
I'm using Propeller Proto Board (#32212)
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Style and grace : Nil point
A mate at work gave up waiting for the skinflint management to upgrade his anchient laptop and started using a more modern one of his own. The second job he went out on happened to have a homemade VGA connection with all the central pins earthed. You could hear the laptops PSU screaching from across the room when he pluged it in. Thank god it was built tough.
