Help. A better way to Fire my LEDs
I've been working through the Stamp works book and I'm having a bit of trouble understanding how take control of my program.· I'm hoping for some help?
Below I have some code to fire 12 LEDs that are setup ready to go 1 through 12.· I'm looking to define my delays·for after my button push·and run through everything in the body of the code prior ro firing anything.· When I use Pause, of course its going through the code consecutively, so I'll never be able to fire LED 1 & 12 at the same time·500ms after the button push.
Can anyone hook me up with an example of how to this better accompanied by an explanation? [noparse];)[/noparse]
' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] Program Description ]----- ' ' -----[noparse][[/noparse] I/O Definitions ]----- ' ' Defines the PIN associated with a LED or Button ' theBtn PIN 0 ' Trigger Button for LEDs LED1 PIN 1 ' LED 1 on Pin 1 LED2 PIN 2 ' LED 2 on Pin 2 LED3 PIN 3 ' LED 3 on Pin 3 LED4 PIN 4 ' LED 4 on Pin 4 LED5 PIN 5 ' LED 5 on Pin 5 LED6 PIN 6 ' LED 6 on Pin 6 LED7 PIN 7 ' LED 7 on Pin 7 LED8 PIN 8 ' LED 8 on Pin 8 LED9 PIN 9 ' LED 9 on Pin 9 LED10 PIN 10 ' LED 10 on Pin 10 LED11 PIN 11 ' LED 11 on Pin 11 LED12 PIN 12 ' LED 12 on Pin 12 ' -----[noparse][[/noparse] Constants ]----- ' ' The LED # Delay Time delays the firing of the LED ' LED1DelayTm CON 500 ' delay time for LED1 LED2DelayTm CON 400 ' delay time for LED2 LED3DelayTm CON 300 ' delay time for LED3 LED4DelayTm CON 100 ' delay time for LED4 LED5DelayTm CON 100 ' delay time for LED5 LED6DelayTm CON 300 ' delay time for LED6 LED7DelayTm CON 400 ' delay time for LED7 LED8DelayTm CON 500 ' delay time for LED8 LED9DelayTm CON 2000 ' delay time for LED9 LED10DelayTm CON 5000 ' delay time for LED10 LED11DelayTm CON 5000 ' delay time for LED11 LED12DelayTm CON 100 ' delay time for LED12 ' -----[noparse][[/noparse] Variables ]----- ' ' Assign Variable to button ' theBtnWrk VAR Byte ' button type variable ' -----[noparse][[/noparse] Program Code ]----- ' ' basic Stamp manual p.139 - Change the value (200) in BUTTON to effect the delay ' its modes: 0 = no delay; 1-254 = varying delays before auto-repeat; ' 255 = no auto-repeat (only one action per button press) ' ' The BUTTON instruction will cause the program to branch to ' No_Press unless P0 = 0 ' ' The body of the program is simply triggering the LED with a delay ' LOW ensures the OUTPUT of the PIN is set TO 0 off ' PAUSE is set under constants and is a way of offsetting the LED response ' HIGH simply fires the LED 1 ' LOW sets the LED back to o off ' Main: PAUSE 5 BUTTON theBtn, 0, 200, 20, theBtnWrk, 0, No_Press DEBUG " ButtonPush " '''' LED 1 Control LOW LED1 ' ensure LED is off PAUSE LED1DelayTm ' Delay LED based on constant HIGH LED1 ' Fire LED DEBUG " LED1 " ' Send feedback that LED fired LOW LED1 ' ensure LED is off '''' LED 2 Control LOW LED2 PAUSE LED2DelayTm HIGH LED2 DEBUG " LED2 " LOW LED2 '''' LED 3 Control LOW LED3 PAUSE LED3DelayTm HIGH LED3 DEBUG " LED3 " LOW LED3 '''' LED 4 Control LOW LED4 PAUSE LED4DelayTm HIGH LED4 DEBUG " LED4 " LOW LED4 '''' LED 5 Control LOW LED5 PAUSE LED5DelayTm HIGH LED5 DEBUG " LED5 " LOW LED5 '''' LED 6 Control LOW LED6 PAUSE LED6DelayTm HIGH LED6 DEBUG " LED6 " LOW LED6 '''' LED 7 Control LOW LED7 PAUSE LED7DelayTm HIGH LED7 DEBUG " LED7 " LOW LED7 '''' LED 8 Control LOW LED8 PAUSE LED4DelayTm HIGH LED8 DEBUG " LED8 " LOW LED8 '''' LED 9 Control LOW LED9 PAUSE LED9DelayTm HIGH LED9 DEBUG " LED9 " LOW LED9 '''' LED 10 Control LOW LED10 PAUSE LED10DelayTm HIGH LED10 DEBUG " LED10 " LOW LED10 '''' LED 11 Control LOW LED11 PAUSE LED11DelayTm HIGH LED11 DEBUG " LED11 " LOW LED11 '''' LED 12 control LOW LED12 PAUSE LED12DelayTm HIGH LED12 DEBUG " LED12 " LOW LED12 GOTO Main No_Press: GOTO Main
The pins P0 through P15 can be controlled simultaneously or independently using these instructions.
Jeff T.
