8 bit envelope generator?
Well I built a simple 8 bit r/2r ladder dac and attached it directly to pins 0-7. Plan is to write a ?simple? ASDR to be triggered by external events. I need to generate 0 -5v cv for Vca hacked from an Alesis Microlimiter. I want to use the bs2 to generate cv based on picking dynamics of my guitar. Any thoughts? Spare parts project once again. Has anyone played with anything like this?
Interesting project you have.
What ever happened with the buffer project from last year?
DJ
Yeah - from those numbers, it does sound like a "rethink" is in order. High impedance, low signal level circuits can be a bear. Yes, please, schematic for the simple switcher.
I have not done anything remotely related to your current project. With that said, I'm mildly concerned that that BS2 would be fast enough to convert audio in this fashion. That's definitely not a "no - won't work"; I'd have to sit down and play with the circuit and see the results (something I'm having to do in my own current project). Schematic for this please?
DJ
