I'm needing a crude VU meter for line level audio
CannibalRobotics
I've got a few spare prop ports and I'm looking for a good way to indicate audio activity at a line level. It does not have to have any unit significance. I just want to drive a handful of LED's for troubleshooting purposes.
I'd like to minimize the number of external components.
Line level is roughly 0 to 1v, 60Hz would be an adequate sample rate. I could smooth the audio via an RC arrangement.
Ideas?
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Ideas?
Jim-
If you just need a boolean, just amp it up and use the prop to do some timeout since last activity type logic. (Minimizing external components... should be easily doable externally though)
Not the fish.
www.hackniac.com
Joe
I'm going insaine. It's SOOOOOO much fun. lol
It is written to run on the Demo board.
To run it stand-alone, you just need to built the ADC circuit (2 caps, 2 resistors).
It needs two pins to do the ADC function, and you'll need pins for however many LEDs you want.
Bean.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
Post Edited (Bean) : 3/30/2010 8:56:06 PM GMT
Jim
