Microcontrolled Online - Test site up
I have gotten my new website recently up and running. I have coded it entierly in HTML in Notepad, so there may be errors. Check it out and see what you think!
microcontrolled.propmodule.com/
Micro
P.S. Before anyone complains about the flash, it is only there the first time the page is loaded.
Don't click on this.....
Use the Propeller icon!!
You had better not start ANOTHER PropII thread.
Micro
Check out my brand new site.
Hello Micro,
You may want to take down your article content at least until it is published in Nuts'N'Volts. Instead you should just show a few pictures and perhaps a brief overview.
Robert
One of the problems with website design is that it won't always look good on each and every browser but yours is looking sharp on Safari at least.
Good job!
@mctrivia: Yes, the homepage has a flash video on the first time it is loaded, but after you navigate away from the page and back it loads in a different homepage file, where the flash video is replaced with a still image (link).
@mctrivia: I just looked at your site. If you are comparing mine to yours, then mine looks horrible.
Please don't be offended, but you should run all your content through a spell checker and have someone verify grammar, etc. It will help with your presentation a great deal.
Also, if you are using vanilla notepad, I would suggest you check out NotePad++ - it's open source and very handy - huge improvement over notepad.
<?php session_start(); if (!isset($_SESSION[noparse][[/noparse]'firsttime'])) { $_SESSION[noparse][[/noparse]'firsttime']=true; } else { $_SESSION[noparse][[/noparse]'firsttime']=false; } ?>then where you want things to show up only first time do this:
<?php if ($_SESSION[noparse][[/noparse]'firsttime']) { echo 'HTML to show on first time'; } else { echo 'HTML to show other times'; } ?>what this does is stores a variable firsttime on my server that is tied to the users visit. If the variable is not there then it is there first visit so it will insert the HTML code between the '' into your page before sending it to the user. if the variable is there then it will send the user the second option.
Nice thing with using php is it is all done on the server and does not mater what browser the user has.
I am also assuming that you saw my workaround to get it to only play once.
Looks great! On the sources tab, I did find this small glitch - Propeller Demo board schematic <a href="
The only other thing is the few typos already mentioned. It is very hard to catch these yourself. Get a friend to proof-read for you and then make the corrections.
It was up fast too!
Whit+
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
I can see the site now that I'm home. For some reason it would
not let me in from my office machine at work.
Pi aren't squared, pi r round!
How about an old school page counter?... [noparse]:)[/noparse]
www.11points.com/images/animatedgifs/counter.gif
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
Open a file.
Copy number
Increment
Save file
Display
You can use session data to remove duplicate counts.
Or better yet use a database and have separate counter for each page.
The reason the "Download all" button does not work is that I am linking it to a file with the ftp subname. What would be the proper HTML code to download a file?
