GPS question about similarity between units
W9GFO
If I don't get an answer to this I will run a test with what I have - probably will anyway...
Will two GPS modules, separated by just a few inches, show the same coordinates? Or at least track with each other in their deviation?
I know that the precise location reported will vary, but will the two units vary consistently by the same amount?
Would it make a difference if the two modules are not identical?
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Rich H
John Abshier
Rich H
- Stephen
This is my guess:
In theory the main error source is related to atmosphere. This is why with a differential GPS you can achieve a 1-2 cm precision (both units are affected by the same atmospheric induced errors, so they are excluded). To do that the units must exchange informations, and there is a lot of processing involved.
2 units with the same error source but operating independently will probably have different results. If they are using different firmware it will be more evident. With two identical units it might depend on the recent history, so you'll probably see them dancing togheter only for a fraction of the time.
Consider with my DGPS changing firmware version makes the fixing different, and you can feel it.
Massimo
Chris Savage
Parallax Engineering
As far as the two units tracking each other, they do. They often change at the same moment, sometimes one will lag about a second behind the other.
I'd really like to see the data out to a couple more decimal places though.
Rich H
obex.parallax.com/objects/225/
It parses the string as they are. You must convert them in case.
Massimo
