Use of LCD
·I have just started to learn to program the propeller. I have been able to redo some of my BS2 programs in spin. My question is, is there a small, easy to follow Demo on the LCD's use with the propeller?? I have seen some but are a little hard to follow right now. Probly will be able to when I become more familure with Spin. Thanks in advance for any help or comments.········
························· Thanxs· Highlandtinker
· Scott
Post Edited (Highlandtinker) : 3/28/2010 11:20:52 PM GMT
· Scott
John Abshier
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Sorry for the large font size ! Didn't know it was a problem.
Mag102:
I am using 2·x 16 and 4 x 20 LCD from Parallax (27976 and 27979) and other ones from Asia with control boards from WWW.Wulfden.org.
· Scott
OBJ debug : "FullDuplexSerialPlus" PUB Main debug.start(0,1,0,9600) waitcnt(clkfreq + cnt) debug.str(string("Hello World!", 13))▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Powered by enthusiasm
No problem. I'll explain why it bothers me though. I view the forums, and most programs, at full screen. I have the fonts sized as small as possible so that the most text will fit on the screen. I have always done it that way. When a post comes up in a large font it literally strains my eyes to read it because I feel like I need to move back a few feet to read it comfortably.
Rich H
·mikediv,
·Tryed to run code but got error saying unable to find···"FullDuplexSerialPlus"
·SRLM,
·Your code loaded but my LCD only shows Parallax's intro screen. This may be a problem with· the··LCD· or· me not understanding· the issue.
·All the help has been a good step forward with understanding the concept of OBJ. Along with··· the······ LCD not showing anything but the intro it has another problem but will take that to the sandbox.
thanks again
· Scott
program has to be in the same directory as the LCD program or the spin tool will not find it that goes for any object you use it has to be in the same directory as the main program
It is set up for pin 16 you may need to edit that in text.start().
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
Post Edited (Brian Riley) : 3/29/2010 4:10:38 PM GMT
Had switchs set right. LCD came on and showed intro then when power was turned off then back on LCD stayed dark. Would change LCD and same thing. Set switches back to test and LCD would work again until power removed. I am going to play with this some more because may be something else going on. Thanks for your valuble help as this is helping me understand the Prop better.
Brian,
A big thanks for the code. I have not tryed it yet but will tonite. Your K107 boards are awsome and I would & will recommend them to anyone.
mikediv,
I thought I had "fullduplexserialplus" put were it belonged but maybe not. I have learned so much from this little project. Mainly that I have so much to learn about the Prop and spin. I had not done any programming since 1986 untill starting with the BS2 a year or so ago. I am far better at the hardware end of electronics but am trying to learn.
Thanks to every one for the help and keep the suggestions and comments coming!!!· Scott
· Scott
I have every kind of screen you can think of hanging off a propeller.. Good luck and don't be afraid to ask there are some awesome guys here very talented and willing to share and help
I am getting kind of bummed out with the whole LCD thing. I agree the Propeller chip is awsome but no matter what I have done so far I can't get any of my Parallax LCDs to do anything but show the Parallax intro screen.
·Brian,
when I try to use the code you posted·(·k107_demo-bst-archive-100329-120317.zip) all but one file· is empty after I extract them. I really am looking forward to being able to use this code. Maybe I will have better luck.
you can e-mail the code to me or repost.· THANK YOU
· Scott
Post Edited (Highlandtinker) : 3/29/2010 10:30:46 PM GMT
Jim
Meanwhile I did an archive by hand.
cheers ... BBR
Thank-You·
· Scott
cheers ... BBR
Anyway, I suppose I should have been more clear. The code that I posted wasn't complete to run. You still need to define your clock. Also, make sure that you have the correct pin on the serial object to transmit on, otherwise nothing will happen.
The complete code:
CON _clkmode = xtal1 + pll16x ' System clock 80 MHz _xinfreq = 5_000_000 OBJ debug : "FullDuplexSerialPlus" PUB Main debug.start(0,5,0,9600) waitcnt(clkfreq + cnt) debug.str(string("Hello World!", 13))▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Yes, my post should have refered to the cursor as an underscore.
Jim
www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp2.pdf
think the light bulb in my head is beginning to glow. ( very faintly, but glowing )
SRLM,
Thank you for clearing up my LCD problem. After defining the clock I was able to get the text to appear.
Not seeing any text on the screen is what was throwing me into confusion. I know the backlight has to be turned on to light the screen. Just couldn't figure out what was up with the Parallax LCDs. They all work ok using your code. So again Thank - you
Scope,
Any and all info is of great help to me. Thanks for the link
· Scott
I have included a bare bones demo file, but it will get you started.
www.wulfden.org/TheShoppe/prop/ - Propeller Products
www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
· Scott
