wireless stingray
Can anyone tell me how to make stingray wireless and do the communication business. i posted a question earlier on sensors forum but i am not getting the right answer. Stingray people haven't given any Rx and Tx output then how to connect the xbee module to it.
Thanx.....
Thanx.....
http://forums.parallax.com/showthread.php?p=892700
http://forums.parallax.com/showthread.php?p=892705
For the stingray, just solder in the 3.3 volt headers (as detailed in the documentation), and use those like any regular propeller pin.
Powered by enthusiasm
You can use any of the available port pins on the Propeller for doing rx/tx with the xbee. When you use the code available on the OBEX to interface wsith the xbee you tell it which port pins to use for rx/tx.
Check out the Propeller Wiki·and contribute if you can.
