Stacks robbing from stacks
I just discovered something that may be already known. In a row of longs like below:
VAR
LONG stack1[noparse][[/noparse]24], stack2[noparse][[/noparse]16], stack3[noparse][[/noparse]24], unusedstack[noparse][[/noparse]17], morestack[noparse][[/noparse]24]
unusedstack was never implemented in the program, so when doing some housecleaning I deleted it, and the program started becoming very erratic. So I put back the unusedstack and things worked fine.
Here is the solution to get the program to work again:
VAR
LONG stack1[noparse][[/noparse]24], stack2[noparse][[/noparse]16], stack3[noparse][[/noparse]40], morestack[noparse][[/noparse]24]
So it looks like stack3 was borrowing from unusedstack all along but I didn't know it since the unusedstack never got used as I planned.
VAR
VAR
Seems more plausible that your code used more than 24 longs starting at @stack3 or removing unusedstack[noparse][[/noparse]17] shifted morestack[noparse][[/noparse]24]'s starting address to an unexpected run-time location. The first is probably true since 24+17 = 41.
Right?
Post Edited (Mike G) : 3/28/2010 8:02:07 PM GMT
Each call to sub-functions needs stack-space. The more parameters and local variables those have the more stackspace is needed. This is especially a problem when you use objects, because you usually won't look into the code to see how much stack will be needed by the objects. And objects using other objects ... ;o)
But if you really want to make the stack as little as possible that's what you should do. Or run tests using the method you obviously found by yourself. Check that a stack does not overwrite into other sections. But testing can be really time consuming.
There's no native stack memory management. You'd have to write that yourself.
Post Edited (Mike G) : 3/29/2010 5:54:17 PM GMT
Yes this was the point, it is well known that you must allocate stack space to fit the bill, what I didn't know was that it would go to the next memory location to borrow from. Although there is stack space obj as mentioned, another method of checking if a stack is running over may be to put a dummy array after it in the declares, and watch to see if any values get changed in the dummy. If this in fact worked, then you could probably watch and see just how short the previous stack is in order to be correct.
The code would look something like the code shown below.
CON
· checkcode = $dead1eaf
VAR
· long stack[noparse][[/noparse]1000]
PUB start | i
· longfill(@stack, checkcode, 1000)
'· Do stuff
· repeat i from 999 to 0
··· if stack[noparse][[/noparse]i] <> checkcode
····· quit
· ser.dec(i+1)
· ser.str(string(" longs used in the stack", 13))
In the past I have come across problems of having not allocating enough stack space, however this is truly a great find.
Post Edited (Rob7) : 3/30/2010 4:31:30 AM GMT
