prop or basic stmap frequcny meter design — Parallax Forums
mikedivmikediv Posts: 825
edited 2010-03-28 18:00 in General Discussion
Hi guys I need a frequency meter ASAP does anyone have a circuit and code for a quick and dirty Freq meter that I can use with a propeller or basic stmap 2 I found one online that was pretty nice it used a pic chip and an 4X20 LCD I had all the parts but one proprietary chip
I am hoping there is a project for the stamp or prop chip which I have displays and the boards
thank you
  • LeonLeon Posts: 7,620
    edited 2010-03-27 22:04
    Frequency? Signal level?
    Leon Heller
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 3/27/2010 11:14:17 PM GMT
  • mikedivmikediv Posts: 825
    edited 2010-03-28 13:34
    Hey Leon ,, I built a signal generator just for kicks for now and I wanted to calibrate it ,, So I would say 20 Meg max down into the 20Ks I was using my scope but I would like to see a hard number,,,, I know you can pick them up cheap online I found a few for 100 bucks
    they were pretty nice. But to be honest I really don't need it so if I could build one with the parts I have it would be cool. I tried searching the Parallax site but the search just done not work for me. I thought I remembered someone building one using the 4X20 and a basic stamp or
    homework board ,, someone emailed they thought there was a project for the Hydra but I can not find that either
    edited 2010-03-28 17:16
    One of the many simple PIC counters that are all over the place will do what you want, and will be cheaper and easier than using a Propeller. You could use a Propeller, of course. You will need an input circuit for it; you could use one of the circuits that are used with a PIC. Sort out the display first, and then write the software for one of the timers.
    I don't think that the Stamp will be suitable, because of the limited frequency range it can handle without external hardware.
    Leon Heller
    Post Edited (Leon) : 3/28/2010 5:38:17 PM GMT
  • hover1hover1 Posts: 1,929
    Mike,
    Would this help?
    ·http://obex.parallax.com/objects/479/
    It's only good to the accuarcy of your crystal.
    Jim
