Wanting to upgrade to Propeller would like advice
I am currently using a BS2 and have been more than pleased with it in my robot projects but I have been wanting to get another stamp or upgrade to the propeller.
I would mainly be using it for robotics. I like the idea of 8 processors in the same chip. My plans so far are to buy the P8X32A-D40 Propeller microcontroller and use
it with the Propeller Professional Development Board. I would like to know if this would be a good move for me. Is propeller similar at all to the BS2? How much is
different between the BS2 and the propeller? What is your recommendation to get started with propeller? Is any familiar with using the professional development
board and how do you like it?
I basically need to know what I need to get and how to get started with the propeller.
Thanks ahead of time.
-Craig
-Craig
You'll probably get better advice here, in the Propeller forum than in the Robots Forum, and as cross posting is discourages (somewhat strongly), you should delete the post in the Robots Forum.
The Prop Pro Development Board is a nice board, but I don't know that it lends itself to robotics, just due to its physical size. If you're just looking for a "learning tool", it would probably work out OK.
I would also suggest looking at the Prop Education Kit (40 Pin Dip Version). This has a nice sized breadboard, and includes the parts required to work through the Propeller Education Tutorials/classes/lessons. It does not include all the inputs and other devices on the Pro Development Board.
For use on an actual robot, the demo board (small, but not much in the way of available outputs), prototype board ("bare bones", or one of the other Prop based boards (from Parallax or 3rd parties) may be more appropriate, depending on the specifics of your robot.
Other than that the Propeller and BS2 are both made by Parallax, and come with the associated support, they are pretty much totally different animals. There are tools (PBasic objects, and now even PropBasic) that you use a similar programming language.
Personally, given the price differences, I strongly encourage you to come over to the Propeller. It is less expensive, and more powerful.
John R.
Click here to see my Nomad Build Log
Have you looked at the Propeller Robot Control Board. Its setup for motor and servo control.
I really love my PPDB (Prop Pro Dev Board). If you can afford it, then I think it's a really excellent platform to use to learn the Propeller.
Also, the MSR1 Propeller Robot Control board is also a really nice board to use on your robots. I have 2 of these (one on my Stingray and one on my parallax wood platform bot).
Check out the Propeller Wiki·and contribute if you can.
Since you've already had plenty of experience with the BS2, I would say that no matter how you approach learning the Propeller you probably can't go wrong. In terms of capability, the Propeller is like an order of magnitude more powerful. The Propeller uses a different language, of course, but it's not so alien that it will bog you down. Once you learn how to juggle the different cogs, The Prop will blow your mind. I sashayed from BS2 to Prop via the "Propeller Education Kit" and lots of help from this forum, whose members very kindly provided tons of support.
It's a whole new world.
Welcome to it!
The prop platform has many great boards including the Platform Universal Adapter Module which will let you use any of the modules available at ucontroller.com/
The propmod-us_ps_sd is a tiny board with all the basics that can easily be squeezed into a robot and then wired to other peripherals.
Which you use depends on what your end goal is.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
http://forums.parallax.com/showthread.php?p=635059
PEKBot: A Propeller Education Kit setup on a Boe-Bot chassis.
The PE Kit is a very good start. I started with a demoboard and it worked great to jumpstart into understanding some SPIN basics and getting to see some things quickly. I am now going through the PE Kit to strengthen my SPIN fundamentals. I use my PPDB to layout and debug circuits/code that will be end up on perfboard or a custom PCB.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Although the code for the Propeller is a little more challenging than PBASIC, the Propeller seems way more capable of doing some really incredible stuff.
Based on what I've learned thus far, I will be using four Propeller kits in my "Introduction to Microcontrollers" class which begins on 14-Apr-10. After carefully considering my options - and there are many out there - I'm taking my students from NXT's directly into microcontroller systems using the Propeller. I'm very new to this and so, take what I have to say with a grain of salt, but the more I learn about the Propeller, the more I'm fascinated by it and the more I'm convinced it's a wonderful way to learn while providing virtually limitless possibilities for future opportunities & growth.
I will always love the BASIC Stamp 2 - it was my first "real" microcontroller experience and I plan on keeping it very busy until I die. But, my Stamp 2 enjoys being busy.
And, that's the way, uh huh, uh huh, I like it, uh huh, uh huh.
Post Edited (Scope) : 3/28/2010 7:51:47 PM GMT
