W5100 and TCP packet size
Timothy D. Swieter
Something is puzzling my mind that I haven't been able to resolve yet. (OK - many things puzzle me, but lets stick to electronics/software here!)
I'm working on the W5100 driver. When reading UDP data out of the buffers of the W5100 the IC adds 6 bytes in front of the data payload and the data contains the information related to IP, port and the size of the payload. It is practically a real UDP header. When reading TCP data out of the buffers there is only data. With UDP I am able to read only a packet at a time out of the W5100 buffers. When working with TCP, how is the program suppose to know how much data is in the TCP packet and how much data to get out of the buffer? I suppose if you have a super fast processing program than perhaps there is only ever 1 packet in the buffer, but the purpose of the buffer is to gather the data until it can be processed.
Any insights? The W5100 hides the TCP packet header info as far I understand so I can't get the details from there either. Maybe the different protocols that use TCP have the data such that when parsing the data it can be recognized and therefore the packet size inferred?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
www.tdswieter.com
He died at the console of hunger and thirst.
Next day he was buried. Face down, nine edge first.
I'm not really good at this, but isn't the separation of streams done by opening different sockets?
You can have a maximum of 4 sockets at the same time, so I would believe that you can handle 4 streams.
Yeah, but Timothy is one layer below sockets. A socket is a stream of e.g. TCP data. If the hardware does not receive TCP headers, you have no way to have more than one socket open at a time. How would you distinguish the raw data in the input buffer without any header?
Who says you can have max. 4 sockets? Is that a hardware limitation of the W5100 module?
You tell the chip you have received the data by modifying a read pointer and writing to some acknowledge register. You may have to implement a FIFO on the Propeller if you run into buffer overflows on the W5100. I don't think this is necessary as the W5100 should be smart enough to only ACK packets it can fit into its buffers, and force the remote host to retransmit data when an overflow can occur.
I think this is a great project. I'm very interested to see how fast you can transfer data over ethernet using the W5100. The ENC28J60 only gets me around 100KBytes/sec, mostly constrained by the slowness of the TCP/IP stack written in SPIN. I just wish I had time to work on a W5100 driver.
That's correct. It also seems that you have to tell each socket which part of the tx/rx buffer it may use.
Me too. Especially I would like to know how fast it is in "indirect/parallel mode".
I tried the SPI mode of the W5100 some time ago, but the ENC28J60 is much faster and more stable in this mode.
I think the concept of streams is what may best describe how to process the data coming in over TCP. The stream would only be the pure data/payload. I think I need to review streams and design patterns around streams to see how I would handle this efficiently in the Prop. Anyone care to explain? I have a thought, but am curious how someone would else would describe it.
Harrison - how would you propose that I do a load/speed test on the driver and hardware I have? At the moment the driver is optimized to be fast in that is uses the counters to clock data out, but I am sure the overhead code could be slightly faster in the SPI mode. Later this week I hope to get the indirect/parallel method going. I would like to do speed test to compare the modes. How did you speed test the ECN28J60?
www.tdswieter.com
