My penguin wont walk
First off I am using program: Penguin-ServoCalibration-v1.3.bpx to try to calibrate my penguin. When I step the values of the Stride Servo it kinda buzzez and shudders a little and then over or undershoots its mark unless I pick it up from the desk and then it will align. After running the alignment and saving the values to E2PROM, I try the Walk command and he takes 1 step gives a high beep and redisplays the debug screen and stops.
Anybody have any help on this???
Often the joy is not so much in the having, its in the building...
It sounds like your Penguin is resetting when it tries to walk. This could be because the Penguin either has low batteries, or it is binding when it tries to move. I would recommend trying fresh batteries, and/or loosening the screws that hold the legs in place. See the third paragraph of Step 5 on page eight of the documentation at http://www.parallax.com/Portals/0/Downloads/docs/prod/robo/27313-6 PenguinDoc-v1.4.pdf for more information about tightening the leg screws.
— David Carrier
Help, saddened Penguin owner with crippled Penguin...
Thanks for your patience.
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
(no longer new) SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
humanoido
Post Edited (humanoido) : 3/16/2010 6:54:12 AM GMT
@macore: your PCB will go out tomorrow. I'll include some new CR2 batteries and test it before we ship.
@vaati: new batteries are likely the cure. Have you tried a regulated power supply?
We don't want any twitching penguins. Always feel free to let us know if you have a problem like the ones you describe above.
Parallax Inc.
and support. Penguin has become one of the most important
biped robots in evolutionary robotics. It's unique combination
of servos, ports, display, compass, infrared system, button
(keyboard), sound, vision sensors, and extremely powerful on-
board processor make it programmable for an incredible number
of applications and unique experiences.
My tests with the rechargeable batteries was a fantastic experience.
Penguin was singing, dancing and walking around all afternoon. I'm
moving the "battery" post to the Penguin sticky so others may benefit
from the idea of using rechargeable batteries.
http://forums.parallax.com/showthread.php?p=890745
humanoido
*Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
*Minuscule Stamp Supercomputer *Tiny Stamp Supercomputer *Penguin with 12 Brains
*BASIC Stamp Supercomputing Book *Three Dimensional Computer *StampOne News!
*Penguin Tech *Penguin Robot Society *Toddler Humanoid Robot Project
*Ultimate List Prop Languages *Prop-a-Lot *Propalot Stuff *Prop SC Computer
*Prop IB Hypercomputer - under development *Hobby Space Program
Post Edited (humanoido) : 3/16/2010 7:08:19 AM GMT
that gives a reference guide to various battery voltages
and their effects on Penguin. Basically anything below 5-volts
will drive your Penguin bananas. The BAT Penguin program
is designed to read the battery voltage level and respond
accordingly. The code has a writeup in Penguin Tech
Magazine.
humanoido
Sighs, ready to put this thing up on the shelf...
Post Edited (Macore) : 3/26/2010 10:51:19 PM GMT
This is really interesting. I'm not sure what's wrong but I'll get my hands on the problem on Monday. Our internal tech support has tested the PCBs and tells me that this problem doesn't exist, so I'll check into it myself. Sorry for the inconvenience - we'll get it straight right away.
Parallax Inc.
Parallax Inc.
I appreciate all your help and stuff though... I think you have a good company and I really enjoy propeller and your sensors and stuff. Too bad you have no Job openings, I am a semi-retired programmer with over 30 years in the industry. I would come out of retirement to work for you guys....
It has a 3-position power switch.
humanoido
Glad to know its working.
humanoido
I tried everybodys suggestions, I tried everything I could think of and nothing changed...
But anyways its ok, I dont want to use the penguin anymore. am returning to the propeller
I pretty much disklike the basic stamp and dont want to use it any more, I am really sorry
that I bought the penguin, sighs
Parallax Inc.
Post Edited (Macore) : 3/31/2010 11:18:32 PM GMT
Sometimes we pull a card out of the deck that's missing a line of print (it happens to everyone now and then), but no problem because Parallax is a company that fully supports all of us whenever we need help. Few, if any, companies in today's fast paced world offer so much support and high quality well designed products.
I can tell you, I've written over a thousand Penguin programs and that's a lot of reliability out of that cute little robot. So when you get up and running, you're welcome to visit our web site (Penguin Robot Society), stay a while, and join in the fun!
humanoido
I found out that I have a Rev. A main board on my penguin, and my power board only has two positions so I guess it's Rev A as well.
As for the batteries, I'm going to rig up a 6xAAA to 2xCR123 adapter and see if that helps fix the problem.
Who can I contact to get another replacement naro servo?
For some reason, I am very unlucky when it comes to my penguin. [noparse]:([/noparse]
Must be because I got it for free....
MCU Projects·- my new site where I will be posting all projects, code, etc.
SD Card Adapter·- Add extra memory to your next Propeller project with ease!
I am working on Robot arm project. What was happening in my project was it drains so much energy and the Robot restarts. And red light blinks again and again like u are saying.
The reason behind that is that there is leakage of current bcoz of that this is happening. Are your battery wires connected properly with it. Hope the negative and positive are not touching each other its not getting contact with some steel surface. Batteries could also be the problem. Do one thingtry changing the batteries to power supply adapter and check with voltmeter. Or try running the servo on serperate power supply.
Or
Other reason could be you are attaching alot of big power servos or something like that to micro controller which is not capable of that
That could be the reasons.
I am just a student. I maybe wrong. Dont get disappointed if it still doesnt work.
I'm going to try my naro servo today using my BS2 to see if it works.
humanoido
Post Edited (humanoido) : 4/8/2010 2:50:19 PM GMT
