Brushless motor control
I want to use a BS2 to controll a sensored brushless motor. I need to read 3 hall efect sensors in the motor and and use a lookup table to match that 3 bit number to a 6 bit output number to drive each phase high low or neutral. I can use lookup and lookdown for the table but how do I asign these numbers to pins for parallel input and output.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
It may use the same PIC16 but what makes it a Basic Stamp is the code that is already on the chip.
Rich H
Rich H
