Engine Diagnostic Pulse Counter
Is anyone familiar with pre-ODB engine diagnostics? I'm trying to trouble shoot the climate control system in my 1995 MB E300 Diesel. They use an error reporting system that outputs pulses, after grounding a particular pin on the diagnostic unit. I know, pretty vague description, but I can't find much information on it. Apparently it is just a front end; the computers communicate on CAN Bus. I've been away from the Propeller chip for a while (got tired of being inside all the time). I'd like to make a small board that plugs into all the diagnostic pins and stores the errors and displays the meanings, not just a code.
So two requests: a more detailed explanation on the early computers and diagnostics than can be found in the wrenchers forums, and the way to set up a counter to count the number of pulses, regardless of duration, without bouncing. I think it pulses pretty slow; slow enough to count them visually with an LED.
This describes the process.· http://www.durametric.com/porsche964faultcodes.aspx
Also, this site·has links to the protocal that porsche, and maybe MB used pre-OBDII
http://pcbunn.cithep.caltech.edu/jjb/Porsche/Motronic-964-Porsche.htm
Especially check out the Yahoo! Group "opendiag"·
Bad spellers of the world untie!
A simple Spin program will be more than sufficient for this, you just need the information on the pulses themselves. Hardware-wise I would just use a high value resistor feeding into a Prop Pin with a pull-down before it.
*Peter*
OK, sorry for the humor here, but I just couldn't resist. Reading thru the posts and a few people were mentioning the CEL and this came to mind. Sorry...
Have to you tried this site?
········ http://www.obdii.com/connector.html
It shows full compatibility for S 320, C 280, SL 320 Models, but your car predates the standard by one year.
Post Edited (Tapperman) : 3/25/2010 8:55:34 PM GMT
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
