ZiCog a Zilog Z80 emulator in 1 Cog - Page 36 — Parallax Forums
1333436383941
  • pullmollpullmoll Posts: 817
    edited 2010-03-17 08:20
    heater said...
    CPD/CPI<r> Still no go.
    I have no time to look at this, we are busy preparing some software for an exhibition/trade show in Amsterdam next week. Does not help that the show is one month earlier than my boss thought it was when he said we should attend!
    Oh, that's pretty normal in our business, or is it? I hear nothing from my contractors for weeks or even month. Then they want something and it had to be done by yesterday.
    Darn CPx! I forgot to do the sign flag in CPI and CPD. Last try.
    He died at the console of hunger and thirst.
    Next day he was buried. Face down, nine edge first.
    edited 2010-03-17 08:22
    Toby Seckshund said...
    Heater
    The solution is always required yesterday ( or the day before )
    Exactly! *me* twiddles thumbs waiting for my contractor to transfer some duties...
  • heaterheater Posts: 3,370
    edited 2010-03-17 08:26
    Damn, just made it into the office. Can't try out CPx till I get home again which might be another 12 hours away.
    edited 2010-03-17 09:31
    heater said...
    Meanwhile I got rld/rrd working and am fighting with the Z80 overflow (P/V) flag on add/adc/sub/sbc. This one is really hairy.
    The formula in MAME is V = ((alu^tmp^0x80) & (accu^tmp) & 0x80) ? 1 : 0; where alu is the result, accu the original value and tmp the addend/subtrahend.
    That is no sign difference between result and addend/subtrahend AND sign difference between original value and addend/subtrahend.
    Hmm.. wait! I just saw that your implementation of the aluops is working! I think I'm going to steal them [noparse]:)[/noparse]
    Post Edited (pullmoll) : 3/17/2010 9:58:23 AM GMT
    edited 2010-03-17 10:25
    Steal away !
    edited 2010-03-18 04:44
    Just a quick EX run before it's back to the office for another 12 hour day...
    cpd<r>........................( 6,144) cycles ERROR **** crc expected:c8439345 found:d7986667
    cpi<r>........................( 6,144) cycles ERROR **** crc expected:e66fa7d2 found:f9b452f0
    [noparse]:([/noparse]
    edited 2010-03-18 06:50
    heater said...
    Himmelherrgottsakrament!
    Here's my working do_cpi function:
    do_cpi        long    (do_cpi_end - $ - 1)
            call    #rd_byte_hl
            mov    tmp, alu
            and    F, #CF            ' keep C flag
            or    F, #NF            ' set N flag
            add    L, #1
            test    L, #$100    WC
            and    L, #$ff
            addx    H, #0
            and    H, #$ff
            sub    C, #1        WC
            and    C, #$ff        WZ
            subx    B, #0
        if_z    and    B, #$ff        WZ
        if_nz    or    F, #PF            ' set P flag if BC is non zero
            mov    alu, A
            mov    aux, alu        ' keep a copy in aux for H flag
            sub    alu, tmp    WZ
            muxz    F, #ZF            ' set Z from zero
            test    alu, #$80    WZ
            muxnz    F, #SF            ' set S from bit #7
            xor    aux, alu
            xor    aux, tmp
            and    aux, #HF
            or    F, aux            ' set H from change of bit #4
    do_cpi_end
    cpir does exactly the same and then jumps back to the start if Z is clear and P is set.
    I hope the trial-and-error cycles will be shorter soon, once I can compile zicog and run tests here.
    This time cpi and cpd were ok, but cpir and cpdr still lacked the partiy = bc <> 0 test.
    Post Edited (pullmoll) : 3/18/2010 9:39:16 AM GMT
    edited 2010-03-18 20:36
    cpd<r>........................( 6,144) cycles OK
    cpi<r>........................( 6,144) cycles OK
    edited 2010-03-18 22:06
    That is another 2 nailed. Well done!
    edited 2010-03-23 10:50
    Hi heater et al,
    I'm looking at getting kermit working for file transfers. There is a generic version of kermit that uses CP/M bios calls and these are can be set up so output is the the 'Punch' device (bios call 4) and 'Reader' device (bios call 3).
    I'm not sure if these are programmed into the SIMH version we are using becase I can't seem to be able to trap these with the io_byte routine. I found some bits of code in spin
    punstat = $12 ' (18)sio port 2 status port
    pundata = $13 ' (19)sio port 2 data port
    I think it is something to do with this command on the simh
    SET SIO PORT=Port/Terminal/Read/NotRead/Write/Reset/Reset/Data
    Anyway, attempts to trap an output to a ptp (paper tape punch) either in pip or in assembly have failed. I was hoping it would tell me there was an unimplemented port, but it just hangs the zicog.
    This is my little test program PUNCH.MAC and it sends one character to the console then one character to the PUNCH device
    ; changing from tasm mnemonics - replace all $nn with nnH
    ; remove . in front of equ
    ; remove : in equ lines
    ; must have a CR/LF after END
    ; no org 100 in mac programs - it is implied
    ; use zasm.sub with supersub
    ; eg supersub zasm myfile    (where myfile is called myfile.mac but do not put the
    ;                             mac in the instruction - m80 knows it is implied)
    ; zasm.sub is the following two lines
    ;M80 =$1 /Z/C/L/M
    ;L80 $1,$1/N/E
    START:
        JP MAIN
    ; 1. Read console - returns an ascii character
    ; 2. Write console - Sends an ascii character
    ; 3. Read reader
    ; 4. Write punch
    ; 5. Write list
    ; 6. Direct console input/output. Send FF to receive character status
    ; 7. Get I/O status of device
    ; 8. Set I/O status
    ; 9. Print buffer. Send entire string starting with address and ending With $
    ; 10. Read buffer. Send address of buffer and return with filled buffer
    ; 11. Interrogate console ready (If LSB is 1 then console character is ready)
    ; 12. Lift disk head and return version number of CP/M
    ; 13. Reset disk system.
    ; 14. Select disk. 1=A, 2=B etc
    ; 15. Open file.
    ; 16. Close file.
    ; 17. Search for a file.
    ; 18. Search for next occurrence.
    ; 19. Delete file
    ; 20. Read sequentially the next 128 bytes.
    ; 21. Write sequentially the next 128 bytes.
    ; 22. Make new file and open it.
    ; 23. Rename file.
    ; 24. Return login vector (which disks are online).
    ; 25. Return current disk.
    ; 26. Set DMA address (to find data records in other parts of memory.Usually boot+80H)
    ; 27. Get allocation vector (for STAT to calculate remaining space)
    ; 28. Write protect disk.
    ; 29. Get read/write status of disk.
    ; 30. Set file attributes (read only etc)
    ; 31. Get disk parameter block address.
    ; 32. Get or set user code.
    ; 33. Read randomly.
    ; 34. Write randomly.
    ; 35. Compute file size for random files.
    ; 36. Set random record position.
    FDOS    EQU    0005H    ; COMMON ENTRY POINT FOR BIOS AND BDOS
    MAIN:
        LD E,65
        CALL WRITE_CONSOLE
        LD E,65
        CALL WRITE_PUNCH
        RET        ; back to cp/m
    ; bdos calls that preserve registers
    WARM_BOOT:
        LD C,0
        CALL FDOS
        RET            ; probably doesn't need a RET!
    READ_CONSOLE:        ; returns answer in A
        LD C,1
        CALL FDOS
        RET
    WRITE_CONSOLE:        ; prints letter in E
        LD C,2        ; FUNCTION NUMBER
        CALL FDOS
        RET
    WRITE_PUNCH:        ; prints letter in E
        LD C,4        ; FUNCTION NUMBER
        CALL FDOS
        RET
        END
    Help would be most appreciated!
    Addit: Getting close to the problem. It is a *read* that isn't working - ie it is trying to read the punch device status on port 18. Hmm - what should it expect? 0x00 and 0x01 or 0x00/0x255 or 32/33
    *Solved*
    Added the last two lines
    PRI on_input
    'Handle Z80 IO port reads
      case io_port
    '    srport:                                             'Altair front panel switches register
    '      in_srport
        simhport:                                           'SIMH control port
          in_simhport
        constat:                                            'Console status port $0F
          in_constat
        condata:                                            'Console data port
          in_condata
        punstat:
          io_data := %00000011                              ' always allow the punch to output as it is an output device
    Now to work on the PRI on_output
    ok, got that working. You can output to port 2 already with these port numbers
    ' UART constants for the second port (male D9)
    port2_test      = $7D                    ' to test if a byte is ready
    port2_io        = $78                    ' for input and output to port 2
    port2_baud      = $7C                    ' set baud rate multiple of 1200 eg 1=1200, 16=19200, 96=115200
    I've also attached the punch device to port 2 as well.
    PRI on_output
    'Handle Z80 IO port writes
    'simhport        = $FE
    'hdskport        = $fd                   ' control port for simulated hard disk
    'vgatext.dec(io_port)
      case io_port
    '    ledport:                                            'An 8 bit parallel output with LEDs attached
    '      out_ledport
        simhport:                                           'SIMH control port $FE
    '      out_simhport
        condata:                                            'Console data port $11
          out_condata
    '      out_constat
        punstat:
    '      PrintStringCR(string("Unknown punch status"))    ' do nothing outputting the status                                  'Punch control port
        pundata:                                            ' connect CP/M punch to port 2
          out_port2                                         ' output to port 2
    This is so cool. The wireless network is attached to port 2. I've got another wireless module coming in via another transceiver module to a RS232 to USB device, and that is on COM3. Teraterm is preconfigured to be COM3. So with one doubleclick on Teraterm I can listen to the network.
    But the really great thing is this uses pre-written CP/M commands. eg PIP - the generic copy program. PTP is the paper tape punch, so I just typed
    A>PIP PTP:=TEST.TXT
    and the text from that file appeared on my teraterm screen.
    Ok, now to get the 'reader' device working.
    Post Edited (Dr_Acula) : 3/23/2010 11:26:00 AM GMT
  • SapiehaSapieha Posts: 2,964
    edited 2010-03-23 11:15
    Hi Dr_Acula
    If I know correctly it is same status bits as on 8251 Intels serial IC
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    edited 2010-03-23 11:25
    Hi Sapieha, yes I took a guess as there are many types of uarts and serial ICs.
    con_status is the console status for the simh so I guess that pun_status would be the same and it is. It was
    00000011%
    But now I am stuck.
    Punch and Reader should be seperate devices. Each should have a status byte and a data byte. But the SIMH combines them into one device, that uses port 18 for status and port 19 for data.
    Normally the Reader would test port 18 to see if data is available and read it from port 19. The availability of data is set by the serial port object running in a cog and is set if Head is not equal to Tail
    The problem is that to get the punch device to output, I set port 18 to say that it is always available. So now the reader assumes there is always a byte. I might need to ask Peter Schorn about this:
    "The second port reads from an attachable "tape
    reader" file on input, and writes to an attachable "punch file" on output. These files are considered a simple
    stream of 8-bit bytes."
    Post Edited (Dr_Acula) : 3/23/2010 11:39:39 AM GMT
    edited 2010-03-23 16:08
    I suspect that port 18 will return different bits for punch and reader status and you will have to and the appropriate bits. Port 19 is simple - if you read you will get a byte from the reader and if you write you will output a byte. Probably one UART is being used for both, so the status bits returnedfor Port 18 are no doubt a normal UARTs status bits.
  • OmikronOmikron Posts: 22
    edited 2010-03-23 18:07
    An idea for TriBlade:
    Because Blade #2 and #1 can be connected together by serial line, it is possible to make the stand alone CP/M computer.
    Only the·PS/2·keyboard and TV or VGA monitor is needed for it.
    Is·such project started already, or should I start it?
    And which kind of terminal do you recommend to emulate?
    edited 2010-03-23 19:02
    Omikron: Absolutely. You need the VT100 terminal emulator for Blade #1. see my signature (terminals) for the links.
    edited 2010-03-23 22:50
    Thanks cluso - yes I woke up in the middle of the night with a vague recollection in the SIMH manual talking about bits. I haven't read the manual as I'm at work now but I suspect that is the answer - different bits set for each port. At least I'm hoping that is the answer.
    Re Omikron- yes you can build a standalone CP/M computer. See my avatar for a photo of one and link below. Everything is a compromise, and the choice is Cluso's two propeller solution which is faster, or the single propeller solution which is about 20% slower.
    edited 2010-03-25 17:46
    HELP
    My board says
    ZiCog 1.0_rc_6.0 on the TriBlade v0.150 96MHz
    Starting HDisks...
    A:ZICOG_A2.DSK 33600 8388608
    B:ZICOG_B .DSK 49984 8388608
    C:ZICOG_C .DSK 66368 33554432
    D:ZICOG_D .DSK 131904 8388608
    E:DRAC_A .DSK 832 8388608
    F:DRAC_B .DSK 17216 8388608
    G:ZICOG_G .DSK 181056 1048576
    H:ZICOG_H .DSK 183104 1048576
    BOOTHDSK.ROM 217984 1024 <-bootcode
    Loading SRAM... Done
    Starting Z80... Done
    ----------------------------------------PC=FF43 AF=D344 BC=2058 DE=0000 HL=0000 IX=0000 IY=0000 SP=0000
    and the register dump is still the same when I turn it off and on again
    I tested the whole A and D buses and they seem to be OK
    When #define SingleStep and #define ShowDiskAccess is on then it can be traced untill that address and then it says HDSK ERROR 2
    Post Edited (Omikron) : 3/25/2010 9:32:22 PM GMT
    edited 2010-04-08 21:41
    Since many people seem to be using ZiCog, here's some more longs to save in the cog:
    test_flag_false   mov   alu, vector
                            shr     alu, #18
                            andn   alu, flags    wz, nr
                            jmp    #vect_w
    This trick saves the xor flags,#$ff that was there twice = 2 longs.
    alu_or               rdbyte  alu, a_reg          'Load A
                            andn    alu, data_8         'clear the bits to OR
                            jmp     #alu_xor_1
    alu_xor             rdbyte  alu, a_reg
    alu_xor_1         xor       alu, data_8 wz, wc
                           andn     flags, #aux_bit
                           jmp      #alu_logic_flags
    This saves just one long, because I need the jump into the XOR code. The trick is to clear the bits that will be XORed to turn the XOR into an OR.
    Pullmoll's Propeller Projects
    edited 2010-04-10 08:39
    That is a cunning trick.
    In a broad sense, re "since many people seem to be using zicog" I'm not even sure exactly what I'm using on the dracblade now. I think it is a LMM 8080 emulation that has elements of zicog and elements of pullmoll's code and some LMM code as well. I'd love to move up to a full Z80 solution but I don't think it fits at the moment.
    There are other elements of pullmoll's code I'd like to add, eg interrupt handling. It is a matter of adding things without breaking existing code.
    edited 2010-04-10 08:55
    Dr_Acula said...
    Just give me some more time. I'm working on the 3rd rewrite of the Z80 core, a mix of vectored cog code and LMM for instructions that are just too big for the cog. The core code (without interrupt handling) is currently down to 2562 longs. With interrupt code in place it's 2615 longs. The latest ZiCog I have is 1852 longs with the DracBlade. The latest yaz80 was 3196 longs.
    I have all instructions emulated, just not the undocumented flag bits, and I still know a place where I could save abt. 40 longs for the cost of slower execution of the shift/rotate operations. Thinking about it I may even be able to get rid of the CB opcodes table by constructing the operand and opcode vector. That would be 128 longs minus the code needed to compose an opcode vector.
    What I would suggest for whatever you're using now is changing the I/O communication to a single long. Instead of having I/O command, port and data in separate longs, I combined them into one long: bits 31..24 = command, 23..8 = port, 7..0 = data. This is faster and wastes less cog space. The new core tailored for the TRS80 has 1 just cog long left - even after moving internal variables to the $1f0-$1ff range.
    Post Edited (pullmoll) : 4/10/2010 10:05:18 AM GMT
    edited 2010-04-10 09:53
    pullmoll: I hope you realise you cannot use all the $1F0-$1FF range as variables as some have different effects.
    edited 2010-04-10 10:00
    Cluso99 said...
    I asked here for the implications of using that range and I'm of course using only the bits that should not have an effect. The z80 cog doesn't use counters or i/o, so I think it's safe to use outa, outb, frqa, frqb, phsa, phsb and vscl full 32 bits. I also use ctra and ctrb, but just for small values, so the counter mode bits are not touched. Here's the map:
            org    $1f0
    __par        res    1                ' read only
    __cnt        res    1                ' read only
    __ina        res    1                ' read only
    __inb        res    1                ' read only
    opcode        long                    ' most recent opcode
    __outa        res    1                ' read/write
    alu        long                    ' arithmetic logic unit (sort of :)
    __outb        res    1                ' read/write
    __dira        res    1                ' read/write - leave this alone
    __dirb        res    1                ' read/write - leave this alone
    postop        long                    ' operation after DD/FD CB disp8 xy
    __ctra        res    1                ' read/write
    daa_adj        long                    ' adjustment value for DAA (reused)
    __ctrb        res    1                ' read/write
    ea        long                    ' effective address
    __frqa        res    1                ' read/write
    tmp        long                    ' second operand temp
    __frqb        res    1                ' read/write
    t1        long                    ' temporary 1
    aux        long                    ' auxiliary flag temp
    __phsa        res    1                ' read/write
    vector        long                    ' opcode vector
    __phsb        res    1                ' read/write
    __vcfg        res    1                ' read/write - leave this alone
    lmm_pc        long                    ' LMM program counter
    __vscl        res    1                ' read/write
    Post Edited (pullmoll) : 4/10/2010 10:09:47 AM GMT
    edited 2010-04-10 13:11
    pullmoll: I use par, cnt, ina, inb as shadow registers for my executing my LMM debugger code and it works extremely well. However, as you stated, it is not possible to use them as gp registers.
    I see no problems with using outa, outb, frqa, frqb, phsa, phsb, vscl providing the counters are disabled and vcfg is disabled although I have not tested them. I like the idea of using the lower bits of ctra, ctrb providing the upper bits are always 0 to ensure the counters are disabled.
    This gives an extra 7 x 32 bit registers and 2 x 23 bit registers providing the upper bits are always 0. smile.gif
  • bazibazi Posts: 29
    edited 2010-05-23 06:20
    I'd like to try ZiCog with CPM and i have a lot of questions, i hope they will be answered [noparse]:)[/noparse]
    I'm reading now for a while in this thread and read that the triblade is the "main-development" board. I had a look at the source code and couldn't find any code which is running outside of *1* cog. So i should be able to use ZiCog with only one propeller, a crystal+eeprom, Keyboard, TV-Out and SD-Card. Is that right?
    Propably i'll try later adding more props...
    I have installed the altairz80 emulator on my computer and did run cpm2.2 und cpm3. Which one should i choose? Does one of them not run on zicog?
    In the altairz80-emulator i have a lot of ram. On the prop i only have 24k of ram, is that right? Do i need external ram? I don't have 3v3 ram, only 512kx8@5V for my 8051 chips...
    I tried turbo pascal 1, 3 and bdsC in the emulator with 24k ram. The pascal compiler compiled mini calculator successful and bdsC compiled tail successful, but the bdsC manual says it needs about 40k ram.
    Obviusly it works, but i'm sure there will be some errors due to lack of ram.
    Can i use my altairz80-emu fdd/hdd-images?
    Can i use a "OS" like PropDOS oder PropCMD in my propeller-eep to load ZiCog from sd card?
    I can't understand why anyone should make a file system without directories...
    some say the devil is dead... ...tish army!
    edited 2010-05-23 07:28
    Hi Bazi, hopefully I can answer all those questions.
    1) 1 cog is needed for the zicog. But you need other cogs to do things like the TV, keyboard, sd card. So all 8 cogs are used.
    2) There was a very early version of zicog that runs on 24k of memory and will run on any propeller board. But you can't do much with that memory
    3) There are a number of boards that add external memory - usually 512k. Triblade is one of those. Also Dracblade.
    4) The 512k ram chips are 3V chip, 55ns. There might be a circuit that uses 5V memory chips but it would need resistors for level translation. And many 5V memory chips are not fast enough.
    5) Yes you can use altair hard disk images. The current zicog/qZ80 emulation uses the 8mb hard drive image (drive i on the simh if you add it).
    6) Yes using propdos to load zicog etc is a great idea. Lots of people have talked about doing it. No-one actually has. But it should be fairly easy to do.
    7) The emulation uses CPM 2.2 or MPM. I think Cluso got CPM 3 working but I'm not sure.
    8) No directories? Yes, this is a very old operating system. Maybe we could emulate an 8088 and do DOS. But there might be copyright problems with Microsoft.
    edited 2010-05-23 13:05
    PropCmd is only an extended PropDos and PropDos is used by RamBlade to load ZiCog.
    Bazi: You will need some form of external memory and that will take pins. On the TriBlade, a single prop is used for the SRAM, SD card, eeprom, optional flash, and 2 serial pins for comms to another prop. The RamBlade is a module that contains 512KB SRAM, prop + eeprom and SD card and 2 pins left for serial comms to another prop or PC running a terminal emulator, or alternately 1pin B&W TV and 1pin keyboard. DracBlade takes a different approach and uses 1 prop and lots of latches to drive the SRAM which sacrifices speed, but saves pins for other I/O uses.
    edited 2010-05-23 13:08
    Hi Bazi,
    Let's see.
    Yes,TriBlade is the board I have been developing ZiCog on ever since a binned by home made Prop Demo Board style board.
    ZiCog only uses one Prop chip though. It shows the CP/M output on your PC in a terminal window. I use the terminal Window of the BST tool.
    You will need to compile ZiCog with BST anyway as it uses "#define" statements that the Parallax Prop tool does not support.
    ZiCog does not support CP/M 3 yet.
    You cannot use the disks from the AltairZ80 simulator as is. The floppy images are in a format that we decided was to awkward for ZiCog as well as being very slow to access. ZiCog exclusively uses the AltairZ80 8MB hard disk image format. But then you need the modified bootloader and that comes with ZiCog and the HD images need to have the ZiCog version of CP/M on the boot sectors.
    So in short you need the HD disk images supplied with ZiCog to boot from. However you can use any othe AltairZ80 HD image as drive B:, C: etc.
    On the TriBlade ZiCog uses 64K of the 512K external RAM for CP/M.
    One makes a file system with out directories when you don't have enough memory space in your machine to hold the code to manage them. As in CP/M and FAT file systems on the Propeller.
    Now if all that sounds complicated. Have no fear. There is an older version of ZiCog that will boot into CP/M using only 24K of Propeller HUB RAM, no ext RAM required. Might be a trouble to find it in this long thread. If you are up for it I will l have a look around on my machine here as well.
    I'm not sure I'd go for adding a RAM chip to your Prop unless you can build exactly a TriBlade Blade# circuit or DrAcula's DracBlade. If you make it different you will spend a long time getting the RAM access code to work. Clusso and Dr_A have already done all that for us with their circuits[noparse]:)[/noparse]
    edited 2010-05-23 14:27
    Ok thanks!
    two people said...
    Building the RAM-circuits of these Boards wouldn't be a problem, but i don't have all these things here and i think thats too much work.
    Isn't there a simple "standard"-way like adding a latch and the sram to a 8051?
    I have a 32Kx8@5V with inputs down to 2V, but i don't know if its enough...
    [noparse][[/noparse]quote]You will need to compile ZiCog with BST anyway as it uses "#define" statements that the Parallax Prop tool does not support.
    I'm using it already, cause i have no windows [noparse]:D[/noparse]
    edited 2010-05-23 14:41
    No, there is no "standard" way to add external RAM to a Propeller.
    External RAM is just bolted on to the normal I/O pins which are then driven by software like any other general purpose I/O. There are a number of such solutions, Clusso's RamBlade and TriBlade, Dr_Acula's DracBlade, the Hydra RAM expantion, Bill Henning's Morpheous and lets not for get Dr Jim's solution. Only the "...Blades" have been running ZiCog so far as far as I know.
    You can probably use a 5v RAM provided you use current limiting resistors on the data bus. I'm no expert about that. But you would then have to hack the ZiCog code to access your RAM if you use your own circuit invention.
    >> "I'm using it [noparse][[/noparse]BST] already, cause i have no windows [noparse]:D[/noparse]"
    Excellent[noparse]:)[/noparse]
    edited 2010-05-23 14:52
    >You can probably use a 5v RAM provided you use current limiting resistors on the data bus. I'm no expert about that. But you would then have to >hack the ZiCog code to access your RAM if you use your own circuit invention.
    Thats (expletive), i've been using 5V sram with an AVR running at 3.3V. The limiting resistors were 100ohm, this didn't work reliable. After days of debugging i wrote a ramcheck-program. It wrote random patterns, read them and gave an error if they weren't equal, I got about 5...15 errors per check...
    So, the only wise way to ZiCog is to order and wait....
