Interfacing a current sense inductor to the stamp
Hello all,
I have several current sense inductors that I have removed from some old ups circuit boards that I would like to use to monitor AC loads in my house (sump pump, laundry, etc.). How would you go about interfacing these devices to the stamp? Here's the datasheet:
www.cooperbussmann.com/pdf/12df78b3-cefd-4bb1-a911-2e4dcc25ecb3.pdf
Tom
Tom
- Stephen
Thanks for the info. I was getting about 75 millivolts when I had it on my soldering station circuit and it went down to practically nothing when I ran it through a rectifier. How would I go about scaling it up to 0-5VDC?
electromanj-
Very perceptive! Yes, I am an electrician. Most people don't make that connection (pardon the pun), even the ones who know what I do for a living.
· Google "precision rectifier" for a sample op-amp circuit that will do the job for you. You can change the gain of the amp to give you 0 to 5 volts to feed into and a/d converter.
· I've attached a sketch of the circuit I've used on several projects. Its for low level DC signals but you can add a precision rectifier on the front end.
Tom Sisk
http://www.siskconsult.com
- Stephen
Tom- Thanks for the sketch. I did a search and found a circuit at sound.westhost.com/appnotes/an001.htm that has a simplified full wave rectifier (fig. 6) that I would imagine I could use to give your circuit a dc input. I have to admit I'm more than a little lost when it comes to analog circuits and opamps in particular, so please bear with me if I need a little more hand holding than most. I'm much better with digital circuits.
Stephen- I'm attaching a drawing of how I had it wired when I tested it with my soldering station. I was measuring ACmV at either side of the resistor.
erco-I like the simplicity of your idea (being that I'm a very simple person!) but am I right in assuming I'd still have to somehow bump up the voltage in order to make that 1.4V threshold?
Thank you all for your responses, but especially for your patience. I'm way out of my league on this one so please forgive me if I'm a little slow to catch on.
Thanks!
Tom
- Stephen
·· At some point you will have to do a test to determine what the maximum sense voltage will be when maximum load current is flowing. Say you measure 1 volt AC when 100 amps flows as a load.
· Set up your precison rectifier and op amps to give some nice output voltage, say 5 volts DC. That 5 VDC will represent·100 amps to the Stamp.
· Without forgetting that this is a great learning experience, you can buy a solid-state 100 A current sensor with 0-5 VDC output for $20 or so at DigiKey.
· Cheers,
Tom Sisk
I took the resistor off the board as well, and I believe it was 48 ohms (I don't have it with me now so I can't say for certain), which would be close to the recommended 50 ohms from the datasheet. So I guess I'm OK as far as that goes.
Tom-
Thanks for confirming the precision rectifier. I'm going to order the parts and try it out. $20 sounds good for an important project (like the sump pump monitoring circuit) but I think I want to try to conquer my fear of op amps first - they do such bizarre things I always thought there was some sort of black magic involved. Maybe I can finally get my head around them. I get a much greater sense of satisfaction if I can learn something in the process of solving a problem. Besides, this is more a case of the parts driving the project, rather than the other way around. I thought it would be cool to recycle some of the parts off these boards, and what better way than to monitor what's going on in my basement when I'm not home?
Thanks again, guys. I'm sure I'll be posting again once I get the parts. On the off chance I actually get it right on my own I'll post my final circuit here.
Thanks!
Tom
For AC loads, I like the Kill-A-Watt meter, which can usually be had off Ebay for $20 or less.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200452163931
Have you interfaced a Kill-A-Watt to the stamp? I have one so I'd be very interested in how you did that.
- Stephen
