Source for small electromagnets?
I have googled and googled, but I can't find a site to purchase small electromagnets.
I am wanting to hold a drop door closed (maybe 5 lbs). It is something I want to hang from a kite. I
thought about micro servos and latches, but I was thinking an electromagnet(s) might save a little weight.
Does anybody have a source?
Other names for relays are solenoid and contactor.
Then in the security system business, they use electromagnets for door latches. Enter an access code or whatever and the door unlatches.
And in the fire alarm business, they use electromagnets to hold doors open in businesses, hospitals, buildings, etc. These are always on holding the interior doors open. When the fire alarm is activated, the power is removed from the electromagnets, then the doors close. This would contain and block the spread of a fire.
Then search google.com for the words...
magnetic locks
...and you will find all sorts of stuff.
If the electromagnet must be ON all the time in order to work, then it will be consuming a lot of power, and power will require batteries that will add weight. You will want a configuration in which the electromagnet needs to be powered ONLY when you want it to perform a function, like pull on a pin, etc. I'm sure you already knew this, but I thought I'd mention it just in case.
For the absolute least amount of weight, though, memory wire is probably the way to go. But it's fussy to work with. You can't solder memory wire: it has to be crimped; and, despite its high force, displacement is small, so precision in the actuator design is paramount.
For cheap,·lightweight servos, have a look at ·http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180399101188
