Futaba Servo Help — Parallax Forums
Futaba Servo Help
NWCCTVNWCCTV Posts: 3,629
edited 2010-03-21 05:09 in BASIC Stamp
Does anyone know if the settings for running a Futaba FP-S148 servo are the same as the standard Parallax servo's when running the sample programs in the WAM manual?
    edited 2010-03-21 00:13
    NWCCTV,
    The code should be the same... what you will need to pay attention to is the particular BS2 you are using, as that might have a different time base that you will need to adjust.
    See PULSOUT in the Stamp IDE software for these timing differences.
    A BS2, BS2e, and BS2pe each have a 2us pulse unit duration which means that a 1500us(<-- Center servo position) would have a value of 750 where as a BS2sx, BS2p, and BS2px each have a 0.8us pulse unit duration. This means that to send a 1500us pulse, the PULSOUT value needs to be 1875.
    Beau Schwabe
    IC Layout Engineer
  • NWCCTVNWCCTV Posts: 3,629
    edited 2010-03-21 00:54
    Yes, I am aware of that. I have a BS2 and a BS2SX with seperate programs for each. I just wanted to make sure the settings etc, were the same. So 750 on the BS2 should be stopped, correct?
    edited 2010-03-21 00:59
    On a standard servo there is no "stopped" Where ever you set it, it will go there and stop. 750 would be close to the middle of its travel.
    - Stephen
  • W9GFOW9GFO Posts: 4,010
    Futaba considers 1.520 mS to be the center value for their servos, which would be 760 for a BS2.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
