Confused? Program doesn't work!!
Spragmatic
I've built a test circuit and program on the Professional·Development Board that works perfect.· I then built the circuit on protoboard while using a SX28 protoboard in conjunction.· When I program the SX28 with the SX-KEY USB it goes crazy.· I/O pins going on and off like a X-Mas tree.· The (2) pushbuttons in the circuit do not respond.· When programed in debug it does same thing and it 's to much for me to troubleshoot.· I'm using the same code and layout as the development board, so I'm confused why it doesn't work on the SX28.· Is there a problem with the new SX-Key editor and the SX28 board?· I've tried it on (2) brand new SX28 boards I've had sitting here waiting for a project.· HELP!!·· Thanks!!
······························· Greg
······· Here's the code--
Can you tell us a bit more about your circuit? What are you using as the clock source? Are you using a resonator, crystal, or 4-pin oscillator? When using the USB key do you have the external clock sources removed? If not that will cause problems.
To troubleshoot why not load a simple program in the chip that just toggles an I/O line every couple seconds that you can watch. Use that the make sure the hardware is working then move on to your program.
Robert
Greg
Jon McPhalen
Hollywood, CA
