*** HC4LED *** Lives Again! — Parallax Forums
Brian RileyBrian Riley Posts: 626
edited 2010-03-19 02:13 in Propeller 1
Hey ... anyone remember Bean's famous (infamous???) HC4LED units??? Well, they are back ... at least for a little while
Terry's company is Hitt Consulting which is the "HC" in "HC4LED". They were bought off eBay salvaged from a cable TV set top box. Nobody knew what to do with them and they were sold off by the pound.
The unit has four seven segment LED displays and an SPI chip on board. It requires only a simple SHIFTOUT command with two I/O lines (Data and Clock) and optionally a third line to enable/disable (alternately it can simply be grounded). It became a big hit. Pretty soon there was code for Parallax BS1, BS2, SXB, and Propeller, Picaxe, various PICs (ASM and BAS), AVRs, Arduino, etc. Sparkfun got ahold of some and they began selling them as well is Hitt Consulting.
And then the well ran dry. If you look about the net you will find any number of HC4LED web pages pointing to the "no longer in stock" webpage at Sparkfun as well as the no longer registered www.hc4led.com some of them loudly lamenting the absence of this neat little unit. Well ... lament no more! Terry found a carton with a little under 200 over 250 more of these units. We made a deal and they are now for sale here, while they last.
www.wulfden.org/TheShoppe/HC4LED/index.shtml
I want to spread them around, so no bulk sales. For now I will sell up to three four units per order. The webpage has a link to the newly updated docs and to an open file download directory for every piece of HC4LED code I could get my hands on (BS1/PROP1, BS2, SXB, Propeller, PIC asm and basic, Picaxe, Arduino, etc
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
Post Edited (Brian Riley) : 3/19/2010 2:05:13 AM GMT
  • BeanBean Posts: 8,129
    edited 2010-03-17 21:49
    Yes folks. Brian purchased the WHOLE box (I think my wife did a little happy dance).
    So if you have any more technical questions about them just ask and I'll try to answer them if Brian does know the answer.
    The speed requirements are quite low, so even a BS1 or a Prop1 (efx-tek). And only 2 I/O pins are needed.
    Good luck selling them Brian.
    Bean.
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
  • John CoutureJohn Couture Posts: 370
    edited 2010-03-18 19:28
    Hey Terry, Do you have any more DS1006 (Quad 4" 7-seg display) units for sale? If so, I'd like to get five.
    John J. Couture
    San Diego Miramar College
  • Brian RileyBrian Riley Posts: 626
    Well I spent most of today testing packing and mailing HC4LEDS. I packed 80 units for shipping, more than half of them made it to the P.O. today. We emptied the carton and did a full count and there were 268 units. In testing 120 or so units we have two DOA, two with 1-3 segments out and two that work but have one or more connector wires broken off.
    The unexpected windfall of 70-80 more units than expected led me to change the limit to 4 units per order.
    cheers ... BBR
