Hardware Resetting for Parallax Internet Netburner Kit — Parallax Forums
yuxianyuxian Posts: 3
edited 2010-03-15 16:28 in General Discussion
Hi, There seem to be a problem with my netburner kit, when I tried to FTP the html files into it, it crashed. Since then, PINK have not been working properly for me, I can visit the factory default page, But often gets disconnection within seconds.
I suspect it could be a corrupted file, so I wish to do a manual Hardware reset.
But I have no idea how to do it, nor did the manual teaches how.
Can someone help? Thanks [noparse]:)[/noparse]
  • yuxianyuxian Posts: 3
    edited 2010-03-13 02:47
    Is anyone able to help?
    edited 2010-03-14 22:11
    I would recommend calling support at parallax on Monday.
    - Stephen
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2010-03-15 02:21
    The Pink is very power hungry. What are you using to power it?
    It's Only A Stupid Question If You Have Not Googled It First!!
  • MoskogMoskog Posts: 556
    I agree with Brian that this could be a power supply problem.
    I used a 9V wall wart and one L7805CV (1,5A) to feed both the Pink and a BS2pe. The 7805 had a heat sink but still got hot.·In my case it was·mostly the BS that reset itself but I also faced·abnormal behavoirs by the Pink.
    After giving the Pink its own 7805 I never faced that problems no more.
