SX28 protoboard in an Automotive application using 12vdc
Spragmatic
I'm using a SX28 protoboard for a project that's going into a new Toyota Tundra. My questions are--
Should I use a dc-dc converter to keep the voltage at the board a constant 12v? (9v-18v in with 12v out {1.25amp} with internal isolation) I'm not sure how the board will handle with voltages ranging from 10-14.6v.
I'm going to leave the on/off switch in the on position with board being powered on through a switched ignition feed. It should be o.k. for long term?
Should I use some type of protection on either the B+ or B- side?
Thanks!!
Greg
Thanks!!
Greg
-Mike
good luck
-MH
