Arccos?!
Hi Guys,
for my autopilot i have do make some arccos and SQRT Operations (Navigation), but i dont know how to.
I could write arccos as 1/cos(...) but i think this doesnt work.
I still use the yahoo Integermath class for other operations.
Edit:
Is there any possibility for making divisions which could return floating point results?
Division and Arccos is used by this: cos(w)=(dz*dlong)/(|dz|*|dlong|) I need w for my traveldirection.
Post Edited (JacE) : 11/18/2009 4:27:18 PM GMT
Edit:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/math/
and get Trig.java (for arccos) and UnsignedIntMath.java (for sqrt)
Both files must be placed in the folder ...\lib\stamp\math
regards peter
Even now my problem is: dividing x and y for deg=arctan(y/x). Y and x are both a part of the position coordinates (i only remove the degree(x=long, y=lat))
Abrasive i try to get the angle, which points towards my target.
I've got my present position in latitude and longitude, and i've got the target position in the same way. Now i try to get the angle between my y-axis and the target with 90-deg.
Certainly i could multiply x and y with big integers, but that wouldn't fix the problem that i get double results.
I've no idea how to deal with this problem.
Okay, i've tried a first solution. it works, but only with small and positive digits:
Post Edited (JacE) : 11/25/2009 4:51:50 PM GMT
then x and y are scaled and then the division y/x is done.
regards peter
Create text folder first if it does not exist.
regards peter
I have used your Trigo file to do some computation, and i divide all the results by 10000 to obtain the exact values. But in doing so, i truncated all the decimal values.
So, I have checked on the net and found that to print floating number can to use: "%7.2f",
However, using Format.printf("%7.2f ",y0); resulted in compiling error.
import stamp.math.*;
import stamp.util.text.*;
public class f {
static void main() {
int h,i,j,value;
int sine, cosine;
int R = 35;
float x0, y0;
Format.printf("sin(x)\n");
for (i=0; i<=3600; i+=45) {
Format.printf("%6d ",i/10);
sine = Trig.sin(i);
Format.printf("%6d ",sine);
x0 = R*(sine/10000);
Format.printf("%7.2f ",x0);
cosine = Trig.cos(i);
Format.printf("%6d ",cosine);
y0 = R*(sine/10000);
Format.printf("\n");
rather it uses integers to represent real numbers.
You need to split the printing to an integer part and fractional part.
For example,·a result in range -1800 to +1799 representing -180.0 to +179.9 degrees
int integerpart = result/10; //signed integer part
int fraction = (result < 0) ? (-result) % 10 : result % 10; //unsigned fraction
Format.printf("%d.",integerpart);
Format.printf("%01d",fraction); //the fraction must be printed with padded zeroes
regards peter
for (i=0; i<=3600*4; i+=45) {
sine = Trig.sin(i/4); //Calculation Up to 1 Decimal pt ONLY
x0 = R*(sine);
Format.printf("%8d ",x0);
cosine = Trig.cos(i/4);
y0 = R*(cosine);
Format.printf("%8d ",y0);
but R*(sine) might overflow for R>3 because sine has range -10000 to +10000
representing -1.0000 to +1.0000
The UnsignedIntMath class provides the methods to do this multiplication
without overflow.
//sine is 10000 based fraction
boolean·negative = (sine < 0);
int sine16 = UnsignedIntMath.dec2frac(UnsignedIntMath.abs(sine)); //convert to 65536 based fraction
//multiply integer by usigned fraction
int result = UnsignedIntMath.umulf(UnsignedIntMath.abs(R),sine16);·//calculate·R*fraction, result is smaller than·R
if (negative) result = -result;
if (R < 0) result = -result; //only if R is signed value
regards peter
Post Edited (StereoPonyz) : 3/12/2010 8:36:04 AM GMT
int result;
//multiply integer by unsigned fraction
switch (sine) {
· case -10000:
· case 10000:
··· result = UnsignedIntMath.abs(R); //calculate·R*1
··· break;
· default:
····result = UnsignedIntMath.umulf(UnsignedIntMath.abs(R),sine16);·//calculate·R*fraction, result is smaller than·R
If you specify R with decimals, for example R = 4000 representing 4.000
then you will get a result 0 to 4000 representing 0.000 to 4.000
regards peter
