In search of the Perfect Button Press
I'm making a simple version of a Space Invaders game using an 8x8 grid of LED's.
I've done a bit of experimenting so that I get familiar with the SX, including the program below by adapting a program from Gunther Daubach's excellent book. For the purposes of familiarizing my self with the SX, I wired up a hex switch to the highest 4 bits of PORTC. Every time I press the button it loads up a hex number and stores it into the first 8 memory locations of the General Purpose section of the data memory, just the way I want it too. Here's the problem though:
If I press the button repeatedly, it won't register all the button presses.
If I hold the button down for too long and then let go, it registers the letting-go of the button as a button press
The program has a timer in it, when I'd rather have the program doing something more important.
Like I said, this is for a fun little Space Invaders handheld game I'm making, so I want the user to be able to mash on the button and be able to send a stream of Led's up to the invaders. The program does work pretty good, just not perfectly.
Basically I'm looking for the perfect button press method.
One press, one registration of doing so
No delay
No hogging the ISR
Thanks in advance for any and all help.
No delay
No hogging the ISR
Include "setup28.inc"
RESET Main
TRIS equ $0f
PLP equ $0e
WKEN equ $0b
WKPND_W equ $09
org $08
Counter1 ds 1
Counter2 ds 1
Counter3 ds 1
Time ds 1
Bounce ds 3
localTemp0 ds 1
org $1e
CopyFSR ds 1
temp ds 1
org $000
; ISR
mov localTemp0, m
;I have to use a copy of the FSR, because the SX automatically resets the FSR
;back to whatever it was when the interrupt started
mov fsr, CopyFSR
mov ind, rc ;put PortC values into whatever FSR is pointing at
;The next section is for checking to see if the fsr has reached the 8th
;memory location. If it has, the program makes the fsr point at 0x10 of data memory, as it was when
;the SX was reset. This is because there are going to be 8 strips of LED's.
mov temp,CopyFSR ;move a CopyFSR into Temp
inc CopyFSR
and temp,#0x07 ;get rid of all high bits
inc temp
sb temp.3 ;If CopyFSR has reached 7, then it's time to reset the CopyFSR back to 0x10 of data memory
jmp Exit_ISR
mov CopyFSR,#0x10 ;reset fsr back to starting point
Exit_ISR
clr Bounce
clr Bounce + 1
mov Bounce + 2, #$7F ;When I adjusted the literal in this line, it acted on only one button
;press like it should
:DeBounce
decsz Bounce
jmp :DeBounce
decsz Bounce +1
jmp :DeBounce
decsz Bounce + 2
jmp :DeBounce
;Now back to administrative stuff for ISR
mode WKPND_W ;this section gets it ready for another interrupt
clr w
mov !rb, w
mov m, localTemp0
reti
org $100
Main
mode TRIS ;Configure port b for i/o
mov !rb, #%11111110
mode TRIS ;Configure port c all input
mov !rc, #$FF
mode PLP
mov !rb, #%11110111
mode WKPND_W ;Reset interrupt flags on portb
clr w
mov !rb, w
mode WKEN ;Enable rb.3 to cause an interrupt
mov !rb, #%11110111
mov CopyFSR, #$10 ;I want the data to start at $10 in data memory
Loop
jmp Loop
www.sxlist.com/techref/ubicom/lib/io/dev/keys/index.htm
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
