ZiCog a Zilog Z80 emulator in 1 Cog - Page 33 — Parallax Forums
1303133353641
    edited 2010-03-09 20:23
    Just kidding, for me, Nascom first then .....
    Style and grace : Nil point
  • pullmollpullmoll Posts: 817
    edited 2010-03-09 21:38
    heater said...
    Here zicog with the working DAA for inspection.
    Hmm.. here the ldi_lmm and ldd_lmm differ in the flags handling. The latter has the flags as MAME's z80 core does them, while the ldi_lmm keeps X and Y flags (should they be set). Perhaps the EXZ80DOC code expects X and Y to not be altered by LDI and LDD?
    He died at the console of hunger and thirst.
    Next day he was buried. Face down, nine edge first.
    edited 2010-03-09 22:20
    Re heater
    1) Add a small Spin method to object that has recyclable DAT space. This new method simply returns the address of the start of the DAT section.
    2) Call that method from your main code and save the address returned.
    3) Start the COG of whatever object it is.
    4) Now you can use the memory from the address you have saved for disk buffers or whatever. Be sure not to use too much!
    That sounds just the sort of cunning plan that I need. I'll check that out tonight when I get home. Hopefully that will free up more than enough for the new opcodes as they are written.
  • heaterheater Posts: 3,370
    edited 2010-03-09 22:28
    The ldi and ldd do differ a bit in that version as was trying some experiments this evening. Previously they had the same flag setting steps and ldd failed. I'm almost sure ldd used to work in the last overlay version. I'll have to run that again. It takes such a long time.
    I'm also pretty sure exz80doc does not care about X and Y flags. It has a mask in there that removes those flags when it accumulates checks sums and then it compares against a "doc" checksum instead of an "all" checksum. Besides many other ops work and none of them set X or Y at all.
    I suspect the problem is elsewhere. For example this EX is using LDIR to shunt things around. LDIR has not been proven to work correctly in this new version.
    Attached is a log of the last EX test run I made. It stops short, with a half dozen tests to go, due to the rechargeable batteries powering my Prop going flat! I'll try another run tomorrow.
    edited 2010-03-09 22:38
    For comparison here is a log of the last EX run on the overlay version of ZiCog. Note ldd works !
    edited 2010-03-09 22:43
    heater said...
    Well, you are right. I took a look at the EX.MAC file on the CP/M disk. Pretty complicated and hard to understand, but the flags mask is obvious.
    You could perhaps shorten the list in EX.MAC and not run the known-to-work tests? That should save some time.
    edited 2010-03-09 22:46
    I've already been playing with EX. Notice all the tests are ordered quickest ones first.
    edited 2010-03-09 23:00
    heater said...
    Well, I didn't see anything obvious in the first sweep. I'll take another look at it tomorrow, after taking a nap. Usually I spot bugs easier in the morning [noparse]:)[/noparse]
    edited 2010-03-10 03:10
    Musings regarding banked memory on the zicog
    I am thinking of getting MP/M running with the zicog. I can see two solutions to running multiple user software. The first takes advantage of the fact that switching banks is very easy by changing the latch settings of the upper bytes on the ram chip. Exit the zicog (with an IN instruction, which might be trapped in CONIN polling for keyboard input, as this means CP/M is idling anyway), store the Z80 registers - especially the program counter, change the bank, get the Z80 registers from when this bank last ran (especially the program counter) and set the zicog running. One could have 8 CP/M machines all running at once.
    But - there are issues with two programs trying to access files at the same time as well as ports, and maybe it might be better to run standard MP/M as this sort of thing has already been coded? Also, I think register A is stored locally in the cog - and I'm not sure how the 'main' spin program could access this?
    Cluso did some work on banked memory. The standard system seems to be to preserve the top 16k and switch in and out the lower 48k. This is possibly easier on the triblade than on the dracblade, but at the simplest level, it needs some sort of trap in the memory access routine with the rule:-If the location is > 48k, then switch in bank 000% and if the location is <48k then switch in the bank nnn% that is currently selected (and I think MP/M needs a way to do that). It might only be 2-3 lines of pasm code to do this - and there is no space free on the dracblade!!
    So - now a question about the new code being written. Firstly, now DAA is done, how many bytes did it end up (bigger or smaller than the old DAA)?
    And the next question - is it possible to sacrifice a little speed by moving one or more other instructions into an overlay or LMM and save a few bytes necessary for running bank code in the memory access routine?
    Why MP/M? Well I'm working on networking and it would be really cool to be happily typing in wordstar or coding in C, but at the same time another board is accessing a file in the background. Wirelessly even. And I think all that this needs is one user on MP/M to be the main user, and another user is the "network" program that is handling file transfers and forwarding of packets etc.
    edited 2010-03-10 06:21
    Your first multi-user CP/M is fraught with problems. As you observe you would need to keep track of multiple open files etc etc. I was wrong in a previous statement, reg A is actually in HUB. That was changed somewhere along the line. However flags and PC are in COG most of the time. Anyway that is the least of the problems with that technique.
    I already added code to ZiCog to do bank switching a long time ago, 48K banked, 16K resident. It uses an OUT instruction to switch banks as expected by CP/M 3 and MP/M. It's behind #ifdefs so is not used and takes no space just now. It has never been tested but works much like you say. Look for "ifdef BANKED_MEMORY".
    One day we will have CP/M 3 and maybe MP/M working. Actually MP/M may be easier to get going as it is built and booted from a working CP/M 2 system. We will have banked memory.
    Big hold up here is that we no longer support the floppy drives. Sadly the CP/M 3 loader only understands floppy drives. I need to modify it for hard drive only system in much the same way as I did our CBIOSX.
    Not sure about MP/M but if I remember correctly one can run CP/M 2 and then start MP/M as a command from there. This means no loader BIOS is required. Only the MP/M BIOS would need fixing for a HD system.
    New DAA is 28 LONGs. Old DAA is 24 LONGs.
    BUT new DAA does not need an overlay area in COG, it lives in HUB as LMM. So 24 LONGs saved in COG.
    Also there is no overlay loader any more saving 14 LONGS.
    Instead the is an LMM virtual machine 5 LONGs (could be 14 for the fast version).
    Pullmoll has discovers a few wasted LONGs in ZiCog, I have added is suggestions.
    Well after all these swings and roundabouts the LMM version of full up Z80 ZiCog I'm running here has 34 LONG's free.
    We may well eat a few of these LONGs while fixing the broken ops but I'm hoping not many as we should be able to do most things in LMM now.
    It is possible to move bits of our "resident" code to LMM if desperate for space. I'm not going to look at that just yet. Not whole instructions so much as most of that code is utility functions or "micro-ops" that are used by many instructions.
    edited 2010-03-10 08:59
    hi heater,
    I'm making some progress on recycling leftover hub space for variables. I'm using the serial port object. Call this after the cog has been started:
    PUB location
       return @entry  ' returns the location of the hub space used by the serial port driver
    DAT
    '* Assembly language serial driver *
    entry
    Then define a pointer for this in the main VAR section
      long buffcogserial              ' location of serial port cog code (for recycling)
    then define it, send it and test it reads back
       buffcogserial :=uart.location                       ' find where the serial port cog code was - must run AFTER cog started
       StoreBuff(5,150,1)                                       ' store a test byte
       vgatext.dec(getbuff(5,1))       ' not working
    but here is the problem. I can send a byte and read it back if it is in the same PUB. But if I run the same code in a different PUB then the byte is not returned.
    PUB Storebuff(i,j,k) ' replace the buff[noparse][[/noparse]] array with the leftover space from the serial driver
        ' i=location (0-255),j=value, k=number of bytes
        i:=i + buffcogserial
        vgatext.dec(i) ' this works
        bytemove(@i,@j,k) ' this works
        j:=0 'this works - clear j to make sure it really reads it back
        bytemove(@j,@i,k) ' this works - read it back
        vgatext.dec(j) ' this works - prints correct value in j
    PUB GetBuff(i,k) | j ' i=location (0-255),j=value, k=number of bytes
        'vgatext.dec(i) ' this works
        i:=i + buffcogserial ' this works
        vgatext.dec(i)' this works, same value as i above
        vgatext.dec(k)' this works
        bytemove(@j,@i,k) ' ? not working
        vgatext.dec(j) ' correct value not returned
        return j
    comments next to each line re which ones work and which ones do not.
    I suspect I'm missing something fundamental in Spin rather than the value not being there.
    Any help would be most appreciated.
    edited 2010-03-10 09:14
    In fix_flags you have
                            test    aux, #%1_0000_0000 wc
                            muxc    flags, #parity_bit
                            test    aux, #%1000_0000 wc
                  if_c      xor     flags, #parity_bit
                            test    aux, #$100 wz
                            muxnz   flags, #carry_bit
    The %1_0000_0000 is the same as $100, so you can do
                            muxc    flags, #(parity_bit | carry_bit)
    edited 2010-03-10 09:28
    Dr_A: Be careful with @.
    @ can get you the wrong address as it is supposed to return the offset from start of object.
    @@ should get you the real address in HUB
    @@@ Is in BST and HomeSpun for cases where none of the above work.
    To be honest every time I think I understand the use of @s in Spin I'm wrong.
    Now: buffcogserial is a pointer, a HUB memory address.
    Therefore so is "i". As in after i:=i + buffcogserial
    BYTEMOVE uses pointers as parameters. So
    bytemove(@i,@j,k)
    may well sort of work but it does not look right to me. It is passing the address of i and j as places to get and put bytes rather than i and j which are the addresses at which to get and put bytes.
    Looks like you should drop The @'s there. You are probably not writing/reading from where you think you are.
    edited 2010-03-10 09:30
    Pullmoll: Great find. I'll put it in.
    edited 2010-03-10 09:34
    @Juergen, I finally worked out what your byline means www.bohseye.com/index.cfm/2008/6/6/Face-Down-NineEdge-First
    That is relevant even today. CP/M has a punch card reader port. I intend using that port for networking...
    @heater, I hope you are ok multitasking here - questions and tasks coming from all directions. Ok, I'm stuck with saving the 256 bytes for the buffer, so I've gone and looked at the banked memory problem. I have found a rather big problem.
    'Read a BYTE from location given by "address" of Z80 RAM into byte data_8
    read_memory_byte
    #ifdef banked_memory
                            cmp     address, common_ram wc     'Address in resident RAM area ?
                  if_c      add     address, bank_offset       'No: Add offset to current memory bank in ext RAM
    #endif
    this is the code from your original zicog with options for the triblade, and it is the beginning of the code that writes to memory.
    I can't add that code on the dracblade as I'm out of longs!
    Yet, logically, testing for the bounds of the memory is going to be best done right at the beginning of read ram code, and at the beginning of write code too. (as indeed it is, but with 3 lines as there is an out of bounds line as well. ? that line not needed).
    So four extra longs there. I deleted those some time ago to fit the dracblade ram driver.
    I see the bank is selected with a write to port $40. That looks pretty straightforward.
    So - how are things going on the LMM zicog with respect to cog memory requirements?
    edited 2010-03-10 09:45
    Be careful with that attempt of banked memory code. It buggers up the "address" variable when changing banks which I'm sure is going to upset a few Z80 instructions that expect "address" not to change after read/write_memory_byte.
    That banked memory code is between #ifdef BANKED_MEMORY and #endif you should not need to delete any lines if BANKED_MEMORY is not defined.
    What did I say? I forget. About 39 LONGs free in COG for a full up Z80! Hope not to eat too many fixing our broken ops.
    edited 2010-03-10 09:57
    ok, memory banking still needs some work.
    great news re free longs.
    good find re the @.
        vgatext.dec(i)
        bytemove(i,@j,k) ' this stores the byte
        j:=0 ' reset j
        bytemove(@j,i,k) ' get the byte back  - this works
        vgatext.dec(j) ' prints correct value
    PUB GetBuff(l,m) | n ' l=location (0-255),n=value, m=number of bytes
        l:=l + buffcogserial ' this works
        bytemove(@n,l,m)
        vgatext.dec(n) ' not correct value
        return n
    I tried changing the variables between storebuff and getbuff but it doesn't help.
    ok, @j is because the variable is going to where j is. but not @i because i is the memory location (somewhere round 23549).
    storebuff is reading the byte back correctly so I'm pretty sure the @j is working. But if you do the same code from getbuff it does not read back (either with i,j,k or l,m,n)
    I wish I understood spin better [noparse]:([/noparse]
    edited 2010-03-10 10:05
    Dr_Acula said...
    Geeky, isn't it?
    What's one little bug?
    But he was determined,               Then change two, then three more,
    The others went home.                As year followed year.
    He dug out the flow chart             And strangers would comment,
    Deserted, alone.                         "Is that guy still here?"
    Night passed into morning.           He died at the console
    The room was cluttered               Of hunger and thirst
    With core dumps, source listings.  Next day he was buried
    "I'm close," he muttered.             Face down, nine edge first.
    Chain smoking, cold coffee,         And his wife through her tears
    Logic, deduction.                         Accepted his fate.
    "I've got it!" he cried,                  Said "He's not really gone,
    "Just change one instruction."       He's just working late."
                   -- The Perfect Programmer
    Did anyone run my uber-geeky pm80_demo? It dumps the entire address space of the prop to Debug_1pinTV.
    Post Edited (pullmoll) : 3/10/2010 10:11:19 AM GMT
    edited 2010-03-10 10:06
    @Juergen - I do like nerd humour!
    Yes, I don't understand spin. Using local variables didn't work. Maybe because the local variables are defined as longs with the | in a pub. So I defined a global variable
    byte testbyte ' byte for buffcogserial
    and then this code does work
    PUB Storebuff(i) ' replace the buff[noparse][[/noparse]] array with the leftover space from the serial driver
        ' i=location (0-255),uses common variable testbyte, moves 1 byte
        vgatext.dec(i)
        bytemove(i,@testbyte,1) ' this stores the byte
        testbyte:=0 ' testbyte
        bytemove(@testbyte,i,1) ' get the byte back  - this works
        vgatext.dec(testbyte) ' prints correct value
    PUB GetBuff(i) ' i =location
        bytemove(@testbyte,i,1) ' this returns correct value in testbyte
        return
    edited 2010-03-10 10:10
    I'm not sure but doesn't vgatxt.dec(n) print the string representing the value of the LONG n ?
    So if BYTEMOVE only sets one byte at n the other three bytes of the LONG at n is undefined and it prints gibbersh?
    Unless n or k are 4 at least in this case.
    edited 2010-03-10 10:27
    @pullmoll: Nice you have found a use for my debug_1pinTV smile.gif
    edited 2010-03-10 10:30
    I don't get it!
    I finally remove the entire buff[noparse]/noparse array and all references to it, replace it all with moving data in and out of the leftover hub space from a cog, it works and boots CP/M (this is vital for all sorts of things including poking the initial JMP in CP/M) and finally I do the grand finale and comment out array in the main VAR section
    'byte buff[noparse][[/noparse]256]
    and it doesn't save any memory?
    Is this real or is it an error with the compiler? I thought adding variables in the VAR section reserved space for those variables
    even more strange:
      byte myarray[noparse][[/noparse]1000]
    and download and it adds no more longs at all. But add myarray[noparse][[/noparse]50000] and it overflows and says out of memory. I'm starting to think the number of longs downloaded to ram may not be accurate??
    Post Edited (Dr_Acula) : 3/10/2010 10:36:09 AM GMT
    edited 2010-03-10 10:37
    Are you looking at the right thing?
    In BST it reports program size, variable size and stack free.
    Program size will not change if VARs are removed.
    edited 2010-03-10 10:50
    Ha, you are right. F8 answers the question. The total goes down. Life is good. Now I can tackle the 512 byte array for disk I/O
    Another question. I am pondering the interrupt for MP/M. If you check for a pseudo interrupt, does that add another pasm line to each instruction in the zicog? If so, that will be a real speed penalty. Ditto a system that says - load bank 2 and run 1000 instructions. You still have to count them. Any way around this?
    I'm looking at the I/O traps - these get called all the time and I've even got ports being polled only every 250 I/O calls. Theoretically, a program could be running that never calls to the I/O ports (eg a really complex math program) and so I/O doesn't work. But for practical purposes, could the I/O routine in the main spin program be used as the interrupt for MP/M to do the bank switching??
    edited 2010-03-10 11:00
    Cluso99 said...
    A big thank you! It's just what I needed for a simple console output smile.gif I only had to export the pRENDEZVOUS as a PUB returning the value.
    edited 2010-03-10 11:10
    Juergen, you have a board?
    Well, out goes the 256 byte buff[noparse]/noparse array and out goes the 512 byte disk_buff[noparse]/noparse array.
    449 longs free. Yippee! That should be plenty to accomodate all the extra overlays. And there are still more to go - eg the 80 bytes used for the 20x4 LCD display.
    I wonder, is this recycling of leftover hub ram a recognised programming technique, and is it used commonly?
    simplify, simplify. This is the little poke routine that starts the initial jump.
        bytefill(buffcogserial+0,$C3,1) ' this stores a byte
        bytefill(buffcogserial+1,$00,1) ' this stores a byte
        bytefill(buffcogserial+2,$FF,1) ' this stores a byte
        RamLatches.DoCmd("W", buffcogserial, 0, 3) ' write 3 bytes in buffcogserial to address 0
    saved two more longs compared with calling a subroutine
    Post Edited (Dr_Acula) : 3/10/2010 11:24:15 AM GMT
    edited 2010-03-10 11:18
    Dr_Acula said...
    Err.. yes! The PropRPM board by elmicro.com. I posted the link in the other Z80 thread some days ago. IMO the pm80 code is ready to be extended by some external RAM access code to throw bigger things at it. All opcodes are there and there's even some space left in hub RAM.
    edited 2010-03-10 11:20
    Dr_Acula said...
    Hm.. wouldn't byte[noparse][[/noparse]buffcogserial+0] := $c3 etc. be shorter than calling that function? I don't know Spin enough, so perhaps the function calls are encoded just as good.
    edited 2010-03-10 11:33
    It would, but this is even shorter. I'm on a roll now!!
        longfill(buffcogserial,$00FF00C3,1)
    Great news with your board arriving. And when you have two, it will be even better.
    edited 2010-03-10 11:38
    Darn it, Juergen, you are fast at picking up new languages. I missed the subtlety of byte[noparse]/noparse vs bytefill.
    So using your logic:
        long[noparse][[/noparse]buffcogserial]:=$00FF00C3
    and that saved one more long.
    You are very good. How many coffees have you had today?
    Post Edited (Dr_Acula) : 3/10/2010 11:49:19 AM GMT
