Protoboard solder problems
I have some issues when soldering my USB proto Boards.
The solder is not willing to stick to the pads as it usually does. Moreover I received with the proto board a couple of X-bee adapters. I assembled the adapters in no time, and used the same male headrs form the set shipped with the adapters on the proto board. So everything is the same, iron, flux, and components.
I was able to solder the header on the board using another flux, more aggressive (I'm also using flux-core solder).
I never had problems, even with veroboards or protoboards old and stored in adverse conditions.
Is someone else experiencing this problem?
Massimo
Massimo
John R.
Click here to see my Nomad Build Log
The first I tested simply refused the solder. I'll adopt your tips.
Massimo
[noparse][[/noparse]wipe, clean; flash a bit on the tip; apply to connection straight away; flow more solder; remove]
If your pads are getting contaminated then clean them off by dragging some solder wick across them.
Massimo
Ken N8SYG
Jim
BTW, it might simply come down to the the board fab's use of lead-free solder to tin the pads, so that they're RoHS-compliant. That may entail the use of a higher temperature to solder components to them than you're used to.
Post Edited (Phil Pilgrim (PhiPi)) : 3/9/2010 9:44:21 PM GMT
John R.
That's kinda of what I was relating to. I have only had it happen·5 or 6 times over the last·20 years.·I know that Parallax has impeccable quality and would never let a sub quality product out of the warehouse. I was thinking of things that happen after the product is opened, spilled liquids, smoke residue, etc.
Jim
Jim
Post Edited (hover1) : 3/9/2010 10:21:22 PM GMT
Could the copper on some boards have oxidized? I'm guessing there is some type of coating/treatment to prevent that. Is this possibly an issue?
John R.
There's no bare copper to oxidize. All the exposed copper is plated.
My first PCBs for my PowerTwig board were ENIG. My production boards are Tin Lead HASL (hot air solder leveling)
Merix has a good PDF download on this page showing different surface finish options currently available from them. Has more details on ENIG.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
Both sides are refusing the solder.
By the way on the bottom there are Parallax soldered pins for DC plug, Xtal, caps and switch, and they look perfect.
Moreover the other board i received with the same shipment accepted the solder with no problems.
Massimo
Gold is very common, even on mass-produced boards. It gives better results with lead-free solder paste and the assembly company I use prefers it.
Leon Heller
Amateur radio callsign: G1HSM
Graham
Graham
edit: vital comma added
Post Edited (Graham Stabler) : 3/11/2010 12:36:46 AM GMT
John Abshier
