Bs2 power supply at 12v
hi my name is Andres
My question is about my input power supply toward the BS2. I will be supplying a 12V voltage and 2.80A maximum current to the Breadboard of the BS2.
So, what you think about the input power supply will damage the BS2 circuit if I use the breadboard of the BS2?
If my power supply is fine, then my second question is: Do you know how I can turn on and off the power supply depending the reading of the Sensor that come from the BS2?
I was thinking using the same pin that use the power supply, then I can make a program for just that pin to turn on and off.
Third question can be done.
Do you have similar programs?
Thank you
Thank you
The Stamp itself draws very little current. Most of the current (and heat produced by the regulator) depends on what you connect to the Stamp and where it draws its power.
The recommendation for a 6-9V power source is based on this heat issue so that heat production will not be a problem at the current drain supported by the regulator (0.8 to 1A typically).
So, the breadboard that I am talking about is the one attached to BS2. So, the max. heat produces will be (12V)*(2.80A) = 33.6 Watts.
Do you think the heat production is fine for this BS2 breadboard.
Do you know how I can turn on and off the pin that input power supply is using from the BS2 breadboard?
I was thinking of using a program to turn on and off that pin depending the reading of a sensor.Do you have similar examples for this goal.
So I need the BS2 breadboard to control the water pump.
www.parallax.com/Default.aspx?tabid=362 Here are the documentation and study guides for Basci Stamps, start a t the top and work your way down.
- Stephen
So I need the BS2 breadboard to control the water pump. Also, I will be connecting a sensor to tell the water pump to turn off or On depending the reading of the sensor.
COMPONENTS
12V Battery with a max current of 2.80A
12v Water Pump with input current of .620A
IR Sensor
BS2
Look at Nuts and Volts Column #6 for a discussion on controlling small motors, relays, and solenoids from a Stamp using a switching transistor. In this case, you can easily run the Stamp from 12V since there's very little current involved. The Stamp itself draws perhaps 10mA. The IR Sensor draws a few mA. The switching transistor will require 10-20mA from the Stamp. That's a total of maybe 25-30mA so the regulator would have to dissipate (12V - 5V) * 0.03A = .21W which is less than a 1/4 W resistor might produce. The motor is powered directly from the 12V supply with a switching transistor as described in the Column.
Nuts and Volts index: www.parallax.com/tabid/272/Default.aspx
Thank very much Mike
