Nokia 6600 Camera for propeller
I have a Nokia 6600 cmos camera. I want to use it on my propeller MSR1 and use it through viewport for object following and recoqnition.
Does someone have the code to run this camera and who can tell me what pins to attach to the propeller?
Pinouts for Nokia camera module connector Mirage 1.3mp
Connector:
Pinouts:
pin: description:
1 Gnd1
2 SDA
3 D+
4 SCL
5 D-
6 CAM Clk
7 VDDI
8 Gnd2
9 Strobe
10 Vdd
11 CLK-
12 CAM VCTRL
13 CLK+
14 Gnd3
Connector:
Pinouts:
pin: description:
1 Gnd1
2 SDA
3 D+
4 SCL
5 D-
6 CAM Clk
7 VDDI
8 Gnd2
9 Strobe
10 Vdd
11 CLK-
12 CAM VCTRL
13 CLK+
14 Gnd3
Leon Heller
Amateur radio callsign: G1HSM
www.8051projects.net/e107_files/public/1233043551_2561_FT3669_6600_nhl-10_schematics_4_0.pdf
Leon Heller
Leon Heller
Leon Heller
Sorry if i offended anyone.
I used the basic atom pro 28 before. This is something totally different. I have some form of dislecty and can learn a lot from just reading the code. But reading a manual to learn the code doesn't work for me.
So if i ask stupid questions, please keep this in mind.
Leon Heller
I would guess that you're impatient to connect the electronics together, apply power; then take a bash at
the coding and devise a solution experimentally.
Unfortunately it doesn't often work that way: it's much better to really research your design, look for the
forum's input, then think hard on the advice received. Then build up the kit; check *everything* twice
before applying power. Then work hard at faultfinding, one section at a time until things start to go your way.
You will still fry stuff, but a lot less of it!
Some of the folks on the forum are extremely experienced and give fantastic advice. For example, Leon
mentioned that you'd be best off using an oscilloscope to progress the mousecam issue. I know from working
with him that he's been at the top of this game for fifty years. I'm quite prepared to argue with him but would
expect to be proved wrong about 100% of the time.
T o n y
Leon Heller
Post Edited (Leon) : 3/6/2010 4:29:14 PM GMT
Post Edited (Fred Hawkins) : 3/7/2010 12:42:00 AM GMT
I re-read my post and my words sounded a bit cocky. This was never my intention and i appoligize...
What i meant to say whas;
"Can you explain me why i need the osciloscope?"
I allready have my answer so thanks guys.
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-31/DSA-601219.html
