Hanno's speech recognition completed at last!!!
I have searched through my project notebook and saw Hanno's specs written down with all but "knows 6 words" and "fits in under 15k" marked off. I then got out Phil's goertzel speech program and started modifying the demo to meat the specifications. 2 hours later I have a functional object and I have finally gotten those last 2 things crossed off the list. Attached is the modifyed speech program and the goertzel object. I don't have a demo for the object written yet, but that will not be hard and I should get one up soon. I will admit that the "GetWordSamples" PUB is a disaster, and while a good consept will not work right yet. I am beginning work on that now and should have it done soon. BTW, special thanks to Phil for another wonderful speech related product.
Micro
Don't click on this.....
Micro
I'm very proud of you for sticking with this project. Controlling Propeller projects by speaking to them will be so cool!
I've sent you a license of ViewPort Ultimate and will include your object in 12Blocks as soon as you're ready. (Congrats also to Phil for his work- he also won a license [noparse]:)[/noparse] )
Time to get ready for the next challenge!
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Jim
@hover1: Thanks!
Attached is the modified code. No demo yet, but it is on the way. I discovered on the old code that the "GetWordSamples" PUB was not working, but this one fixes that error.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Graham
·http://forums.parallax.com/showthread.php?p=821251
Phil's Goertzel-based speech "recognizer"
·http://forums.parallax.com/showthread.php?p=837331
Use the Propeller icon!!
Why couldn't a Propeller be programmed to recognize a face? Heat sensor maybe?
OBC
New to the Propeller?
Every time that you think the ol' Props not capable of something...... it is. I bet $10 BradC will be the first one running Linux on it.
I'm still waiting for the voice recognition demo video [noparse]:)[/noparse]
*Note: famous last words.
