Is One Parallel Capacitor Enough for Small Tamiya Motor?
· I'm·wiring up a pair of small Tamiya motors for 5 volt use.·· ·I see different noise filtering configurations using up to three capacitors.· I'm using a Pololu Dual Serial Motor Controller.· Has anyone out there found a single .1 uf. capacitor mounted between the each pair of motor terminals to be sufficient?· I don't really want to run to Radio Shack for extra capacitors if I can help it.· I will do what it takes to make sure the motor noise doesen't interfere with the Stamp I am using (including walking to the Shack ........if I must).· Anyone out there running this combo with just one capacitor per motor?
I did have a lot of controller thermal shutdowns·with those motors if I ran them full tilt.· I think I read on Pololu's web site that the motors were more than the controller could handle.
edit:· I had to put the caps across the logic and motor supplies near the controller,·not the motor outputs.
Post Edited (agfa) : 3/5/2010 4:03:18 AM GMT
0.1 uF caps are very useful for may apps, stock up and keep them handy. Hosfelt sells them for about a nickel each. Buy a hundred!
Curious that the new Stingray robot has no motor filter caps at all.
·· ·I also had some problems with the motor controller when I first tried it last year.· I remember doing away with the reset line for some odd reason.· I'm sure·it had to do with noise issues from the motors.·· I might agree that these motors may be drawing too much current under some conditions.
·· ·I wonder if ramping-up the motor current will help?· I'm stuck with this wheel and gearbox/motor combo because my chassis has been designed around it.· I've taken steps to protect the exposed gears from debris and muck because I saw this as a problem in my early prototype.· A rock or wound-up carpet fiber in the gearbox would definitely overload the controller.
· Sorry erco..did'nt see your post.· Is there enough info provided?· The bot uses a PS2 mouse shell, 4-AA cells , OEM BS2x board, Pololu Micro Dual Serial Controller, and no caster installed.· Does this give you a ballpark weight?· I need a scale...· Do you know the available ratios for the Tamiya Twin Motor combo (not to be confused with the Tamiya Dual Motor Gearbox which is beefier).?
· I really should not complain...the Radio Shack is ONLY A BLOCK AWAY!
Post Edited (Mikerocontroller) : 3/5/2010 4:41:44 AM GMT
The unusual behavior I experienced had nothing to do with motor or load.· I used single caps because I was afraid of damaging the motors while soldering to the case, and there wasn't enough of the case exposed without modifying the gear box.· I believe ramping helped,·Pololu did·recomend it, in fact I wasn't ramping when I experieced the shutdowns.· If you think it·will help I can scan·my copy of the·instructions for you, just pm me an email address.
Post Edited (agfa) : 3/5/2010 1:08:20 PM GMT
Yes, wonder why that is? Are it's motor's less noisy (electrically speaking?) or does the Stingray's motor control circuitry have something to take care of this?
I saw that you had added these to poor cousin. I know they are also present on the Scribbler. I know this is often done.
What exactly does it do? And how does the configuration aid this?
@Mikerocontroller - thanks for asking this. I meant to PM erco and ask about it after I saw the pics of the Poor Cousin (aka RetroBot) in Robot Magazine.
Whit+
I think I answered my own question - see here http://www.beam-wiki.org/wiki/Reducing_Motor_Noise
Whit+
Check out the Propeller Wiki·and contribute if you can.
The Stingray motors are standard Chinese brushed DC gear motors. They make the same electrical noise as any other small DC motor, even if they have their own seperate power supply (is this really how the Stingray is set up, Roy?). At that low 30:1 gear ratio, there's a lot of current flowing there under acceleration: more current is more noise. It's generally good practice to put 1-3 filter caps on all DC motors to reduce unnecessary electrical noise & spurious emissions. It prevents some problems and head-scratching. Sure couldn't hurt to add them to a Stingray.
As you saw, Whit, Retrobot does use three filter caps per motor. Those are gigantic mylar ones in the photos, but they're still 0.1 uF. First ones I grabbed off my bench. Small ceramic 0.1 uF units are fine, too. I think I needed the extra weight for traction!
@Roy - the Stingray comes standard with a single power source for motors and electronics (Six AA rechargables).
Whit+
In any case, I've had no issues so far·running the stingray with the motors going full speed.
Whit+
Jax
If a robot has a screw then it must be romoved and hacked into..
