Urt.java
I have been looking through the code for Uart.java that was supplied with the Javelin Stamp IDE
The file in question is in lib/stamp/core
I am not sure about the following code
public int receiveByte() {
int b;
if ( vpBank == NOT_INSTALLED ) {
return -1 ;
while ( true ) {
int headPointer = CPU.readRegister( vpBank|nmUartHead );
int tailPointer = CPU.readRegister( vpBank|nmUartTail );
if ( headPointer != tailPointer ) {
int index = tailPointer>>1;
if ( (tailPointer&1) == 0 )
b = (byte)(buffer[noparse][[/noparse]index] >>> 8);
else
b = (byte)(buffer[noparse][[/noparse]index] & 0x00ff);
tailPointer++;
CPU.writeRegister( vpBank|nmUartTail, tailPointer );
break;
// Inform the receiver so it can do the handshaking.
rxRead(vpBank);
return b;
I suspect the line b = (byte)(buffer[noparse][[/noparse]index] >>> 8);
should be b = (byte)(buffer[noparse][[/noparse]index] >> 8);
There is no class with this code so I am not sure how and when it gets compiled.
It compiles clean using the IDE but it will not return the correct result.
Regards
Don
int b;
return -1 ;
while ( true ) {
else
tailPointer++;
break;
rxRead(vpBank);
return b;
Regards
Don
and use the Uart object.
The code is ok. The >>> denotes an unsigned shift, whereas >> denotes a signed shift.
regards peter
I have been writing Java for many years and never come across the
unsigned shift. Looks like I can improve some of my code !!
Regards
Don
but it is a helpful one for javelin programming as there are no unsigned ints.
The workaround for·>>> N using >> is
while (N > 0) {
· value = (value·>> 1) & 0x7FFF;
· N--;
regards peter
